Five speed in a-body's? #211288
02/01/09 09:01 PM
02/01/09 09:01 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
How many guy's out there have installed or have a doug nash or richmond 5 speed in their a-body cars. Easy swap major modifications, i'd like to know, thinking of rowin five Thanks
Re: Five speed in a-body's? [Re: rowin4] #211289
02/02/09 12:20 PM
02/02/09 12:20 PM
rowin4 Offline OP
rowin4  Offline OP
got to be some one out there
Re: Five speed in a-body's? [Re: rowin4] #211290
02/02/09 04:07 PM
02/02/09 04:07 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
I wish I did.I'm still runnin' the Hemi box.
Chris
Re: Five speed in a-body's? [Re: rowin4] #211291
02/02/09 04:53 PM
02/02/09 04:53 PM
AndyF Offline
AndyF  Offline
I have a Doug Nash in my B body car. You have to cut out the torsion bar crossmember and some of the floor. No big deal for a street rod type fabrication place.
Might be a good idea to switch to an AlterK type of front end and ditch the T bars. Then it doesn't matter that the cross member is gone and you get the strength back with a tranny crossmember instead.
Re: Five speed in a-body's? [Re: rowin4] #211292
02/02/09 05:05 PM
02/02/09 05:05 PM
Connecticut
5126brl No more Offline
Connecticut
What are you running now?
Specs
I am in need of a race 4-speed setup! I do not want to cut up the floor.
Re: Five speed in a-body's? [Re: rowin4] #211293
02/02/09 08:13 PM
02/02/09 08:13 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
I had a Doug Nash in the dart and had to cut the crossmember and modified the shifter hole ~ 1" if I remember correctly. I fabbed a trans mount out of 1 1/2 square tubing off of the subframe connectors. Make sure you get the DN with the countershaft support bearing they hold up better.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Five speed in a-body's? [Re: gearjammerdart] #211294
02/02/09 10:22 PM
02/02/09 10:22 PM
rowin4 Offline OP
rowin4  Offline OP
Thanks for the feedback guy's, looks like major modifications to the crossmember. will get a workout and also
Re: Five speed in a-body's? [Re: rowin4] #211295
02/03/09 12:17 AM
02/03/09 12:17 AM
Roanoke Va
Roanoke Va
I made two cuts on the crossmember at the same angle of the driveshaft tunnel and used a air hammer to cut the spot welds on the floor pan took about 15 min tops.
