Spax Double Adjustable shocks #2112161
07/18/16 12:35 AM
07/18/16 12:35 AM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
I haven't seen any feedback on them, but they are available for our cars. Their website doesn't show shipping to the colonies, but an e-mail shows they do. Since the Pound has been taking a post brexit beating I'm going to take a shot. The cost for a set of 4 including shipping is £371.64, or $483.13. Hard to pass up on that- for me anyway.
Re: Spax Double Adjustable shocks [Re: Skeptic] #2112365
07/18/16 12:17 PM
07/18/16 12:17 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Not much here on them on this forum, but the hard core mopar corner guys have been using them for quite a while. Never read anything bad about them other than cost, but given the critical nature of shocks, its a justifiable cost.
Re: Spax Double Adjustable shocks [Re: Skeptic] #2112600
07/18/16 05:51 PM
07/18/16 05:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Only shocks I could find listed for the Jensen Interceptor.
Haven't installed then yet, but I think they have around 18 adjustment "clicks"?
Re: Spax Double Adjustable shocks [Re: 451Mopar] #2112752
07/18/16 08:55 PM
07/18/16 08:55 PM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
The shocks I'm looking into have "28 stage Bump & Rebound damping adjustment" Right now I'm waiting on a response from them about their hours of operation. They don't accept PP and I'm not comfortable e-mailing my CC info. So I need call and it looks like they are 8 hours ahead of me.
Re: Spax Double Adjustable shocks [Re: Skeptic] #2112925
07/18/16 11:50 PM
07/18/16 11:50 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
I bought a set 10 years ago through a group buy off the Mopax e-mail list. I think it was through "Apex North America". Pretty sure it was a special order deal. I have a phone number you could try. Not for sure if this was business or personal, so I will send it to you PM and you can find out.
G480 are the front. Rear needs bushings which you have to buy separate.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Spax Double Adjustable shocks [Re: 68cuda440] #2112944
07/19/16 12:04 AM
07/19/16 12:04 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
I assume these would be adequate with 1.12" torsion bars on an A-body with 225# springs in the rear? Anyone have experience with these on the larger bars?
Irony is I have been wondering what I would do for shocks, and you reminded me that I had these in my stash.
Re: Spax Double Adjustable shocks [Re: 68cuda440] #2112982
07/19/16 01:04 AM
07/19/16 01:04 AM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
Thanks for that info, The bushing situation isn't mentioned by Spax website nor the sales rep I've been dealing with.
Re: Spax Double Adjustable shocks [Re: 68cuda440] #2112992
07/19/16 01:13 AM
07/19/16 01:13 AM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
I'm hoping so, I'm running the 1.12" bars in front, I've got the Hotchkis rear leafs, relatively soft at 130 lbs/in.
Re: Spax Double Adjustable shocks [Re: Skeptic] #2112993
07/19/16 01:15 AM
07/19/16 01:15 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
My rear shocks, part number G3287, are new in the box, and as can be seen in the picture - no bushings.
Bushings I have are two sets of Energy Suspension Part Number 9.8110G. I am just assuming these are correct, they are sitting on top of the rear shock box. I think I just bought what someone told me was correct, they look correct if that helps.
http://www.energysuspensionparts.com/9.8110
Re: Spax Double Adjustable shocks [Re: 68cuda440] #2113013
07/19/16 01:55 AM
07/19/16 01:55 AM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
Thanks, I found a Spax vendor on E-bay that is located in the Maryland location. The cost is better than direct from Spax. I was thinking that the shock bushings shouldn't be difficult to pick up. I just got a response from Spax, the rear shocks now come with a bushing, as of the end of 2015.
Re: Spax Double Adjustable shocks [Re: Skeptic] #2115857
07/22/16 10:45 PM
07/22/16 10:45 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I've installed the SPAX shocks. I'm still using the older version (just 14 clicks, so slightly coarser adjustment). They are not double adjustable, but the last few clicks in the range effect both compression and rebound.
The G480 & G481 shocks are designed for Australian valiants and need some minor mods to fit the US & UK A-bodies. Front shocks need the bushing sleeve opened up very slightly with a drill or reamer. Also SPAX ran out of bushings for the rear shocks, so you need to install your own bushings now. (this was some years back, situation may be different now).
For the rear shock bushings, I used polyurethane Chrysler 5/8" Shock Bushing (Energy Suspension #9-8112G). The 11/16" inner diameter was not available. However all of the other dimensions are correct, so its "just" a matter of drilling out the center. Although easier than drilling rubber, the bit still wants to tear rather than cut the soft material. Freezing helps make it stiffer. After drilling, I cut the bushings in half with an Xacto razor saw and a sharp utility knife. By making two halves, the bushing does not need to pressed in.
My old What's it Got? - Suspension webpage and more on Dave's Goldfish Page, halfway down. Lame Horse Racing - Goldfish He used a different bushing with success.
Re: Spax Double Adjustable shocks [Re: Mattax] #2118401
07/26/16 08:07 PM
07/26/16 08:07 PM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
They showed up today, no bushings on the rear frowwn Not shock though. I'll make some measurements and order from SummitClaus. Hey, it's just like Xmas, including the CC bill.
Re: Spax Double Adjustable shocks [Re: Skeptic] #2119333
07/27/16 08:29 PM
07/27/16 08:29 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
See if this is correct: http://www.energysuspensionparts.com/9.8110
I have two sets if you need something measured.
Re: Spax Double Adjustable shocks [Re: 68cuda440] #2120213
07/28/16 10:23 PM
07/28/16 10:23 PM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
Thanks, It'll probably be a couple of weeks before I get to the back to check stuff out. This weekend I'm pulling the Pass side suspension off to install the heim joint boots and install the steering column. luck wave
Re: Spax Double Adjustable shocks [Re: Skeptic] #2121114
07/30/16 06:06 AM
07/30/16 06:06 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
How do Spax compare to the Viking shock? what would be applicable to a B-body?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Spax Double Adjustable shocks [Re: astjp2] #2125306
08/04/16 11:21 PM
08/04/16 11:21 PM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
I'd say the Vi-king shocks are a step or two above the Spax, they are true double adjustable and the valving can be customized. They are more expensive too. Can't help with the B stuff, it's just min-max length and bushing opening.
I'm not going to be wrenching for a few weeks, broke a finger @ work, first time in 32 years I got hurt that I couldn't work. Still I'm @ work, just doing some paperwork. Just puts a serious crimp in the Ricer Cuda work.
Re: Spax Double Adjustable shocks [Re: Skeptic] #2385091
10/10/17 02:17 PM
10/10/17 02:17 PM
Round Rock, Tx
PlumCrazyChris Offline
Round Rock, Tx
Do these SPAX shocks work on a lowered car? I have QA1 single adjustables and they are bottoming out. I had to use lowering blocks on the rear shock pad to keep the rears from bottoming, but I have no options like that for the fronts.
VP of Mopar Muscle Cars of Austin
70 Challenger
www.mopar.org
Re: Spax Double Adjustable shocks [Re: PlumCrazyChris] #2385517
10/11/17 11:11 AM
10/11/17 11:11 AM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
You need to measure the compressed length and see. shruggy I've had a lot of health issues over the last year-all work related, and am just getting to a point where working on the 'Cuda is feasible, and have decided to stick with the installed RCD shocks for now.
