Re: Hellcat Block Pictures
[Re: hudsonhornet7x]
#2110548
07/15/16 03:04 PM
07/15/16 03:04 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Everything looks good, would like to see the mains if possible. Would also like to see sonic numbers.
Mopar to the bone!!!
#2110622
07/15/16 05:11 PM
07/15/16 05:11 PM
72Swinger
Nebraska
Thanks for sharing, are you Chief 6.4 on MMF?
#2112275
07/18/16 07:44 AM
07/18/16 07:44 AM
Posts: 2,410 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
That's cool! Would like to watch your project come to life, you posting it somewhere?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
#2114716
07/21/16 12:41 PM
07/21/16 12:41 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I will flip it around tomorrow for the mains. Don't know when I will get sonic numbers Just ordered mine. Any chance you got those sonic numbers? As soon as I receive mine I'll have numbers. Matt
[Re: STEFF]
#2115037
07/21/16 07:12 PM
07/21/16 07:12 PM
MattW
Ontario Canada
Don't get too excited about the sonic numbers, thinking they can be punched huge. It won't be thicker than what you already see with existing blocks. Meaning minimal material..... Even though the numbers will be minimal I do believe they are cast with better material. I've never heard of one splitting a cylinder. Steff did you ever check yours? Matt
#2118630
07/26/16 11:16 PM
07/26/16 11:16 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
How much stronger is this hellcat block, I'm thinking about getting one and build a twin turbo engine for 2000hp
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
#2240460
01/24/17 03:55 PM
01/24/17 03:55 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Been thinking about buying on of these, odd question, but what side is the starter on? I want to build a 6.2 for a 2003 ram that I want to put an A833 in,
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: fbs63]
#2240676
01/24/17 10:15 PM
01/24/17 10:15 PM
MattW
Ontario Canada
Looks like it still has powdered metal main caps. These things are as good as an R3 as you will get. Half the cost and no machining. The new Demon variant has more HP Rumours approaching 900 hp. These blocks are stout! Matt
#2252510
02/12/17 08:11 PM
02/12/17 08:11 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
What is the price of these blocks and can you just purchase a stroker kit and drop it in without machining?
A new iron curtain drawn across the 49th parallel
#2252631
02/12/17 10:59 PM
02/12/17 10:59 PM
67autocross
Manitoba Canada
Really not much point doing a regular small block Mopar if you are starting from scratch, just need to figure out what heads to use.
[Re: Dadodgekid]
#2254734
02/16/17 08:51 PM
02/16/17 08:51 PM
MattW
Ontario Canada
426ci hellcat block seems rather enticing! with the newer blocks, could you use the 32tooth reluctor cranks and older style cams to get away from the VVT and go with an MSD6 CDI? I try and keep it simple... Yes on the reluctor wheel , NO on the cam. But all you need to do with the stock cam is lock it out. Comp cams has a kit.
[Re: dogdays]
#2254998
02/17/17 01:27 PM
02/17/17 01:27 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Yeah, makes it really hard on those of us with a mountain of obsolete LA stuff. Now I'm two generations behind, first the Mag and now the Hemi.
R. Ha! I've yet to build a stout small block anything... I'm still in Purple Shaft land... At that price, wow. It's hard not to justify doing Gen 3 over LA or big block stuff...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
#2255005
02/17/17 01:43 PM
02/17/17 01:43 PM
72Swinger
Nebraska
Been Gen III Hemi for almost 3 yrs. No regrets, wanted a high powered reliable, efficient, pump gas engine and it is that in spades.
[Re: JandJ_Racing]
#2504637
06/05/18 01:42 AM
06/05/18 01:42 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Anyone working with the 6.2 block yet? Curious about using a 5.7 cam core?
Brian Hafliger
#2504825
06/05/18 02:21 PM
06/05/18 02:21 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have one and the cams look identicle in fitment dimentions
#2504828
06/05/18 02:27 PM
06/05/18 02:27 PM
HotRodDave
Kalispell Mt.
I think the 5.7 cam may be better to start with as the base circle is not ground down as low.
Anyone care to elaborate on the supposed machining difference in the BGE and hellcat? I dont see any...
#2504890
06/05/18 04:26 PM
06/05/18 04:26 PM
HotRodDave
Kalispell Mt.
I got mine used for $300 off the line.
