Page 6 of 11 1 2 4 5 6 7 8 10 11
Re: My bracket hemi build [Re: Triple Threat] #2104237
07/05/16 02:14 PM
07/05/16 02:14 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
I'll call this post a reliability update, been beating on this thing basically every weekend and haven't had any hiccups. Probably 75 runs on it now.
Ran a new best this weekend of 10.23@131, still 3500# of machine here. Really need to work on the 60 foot as that was only 1.46, It wants more gear and converter.
Made 17 runs on Saturday double entered into Pro and Footbrake (won Pro, R/U in Footbrake). Another 7 runs Sunday (won Pro). 24 passes in two days, on Saturday in the late rounds I made 5 runs in under an hour. Trans was smokin hot, but the engine just kept chugging along.
Everyone loves the hemi!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My bracket hemi build [Re: Triple Threat] #2104302
07/05/16 04:11 PM
07/05/16 04:11 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am going to steal this quote for my newsletter, thank you, Dustin.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: My bracket hemi build [Re: Triple Threat] #2104463
07/05/16 08:47 PM
07/05/16 08:47 PM
Canada
onig Offline
onig  Offline
Canada
Good job Dustin.
That is a well put together engine.
And congrats on those wins. Have you won enough money to pay for the build yet?
Onig
69 Dart
Re: My bracket hemi build [Re: onig] #2104861
07/06/16 12:40 PM
07/06/16 12:40 PM
Renton Washington
Renton Washington
Originally Posted By onig
Good job Dustin.
Onig
Thank you, only a bit over $4K winnings so far this year, still have a ways to go.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2105442
07/07/16 02:59 AM
07/07/16 02:59 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I am real glad to hear that it is a happy motor! Keep up that check cashing
"Just a Bracket car dressed up like a streetcar"
Re: My bracket hemi build [Re: Triple Threat] #2105752
07/07/16 04:45 PM
07/07/16 04:45 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
you are THE MAN!!!!! bad ass
Re: My bracket hemi build [Re: Triple Threat] #2105947
07/07/16 11:07 PM
07/07/16 11:07 PM
cedar rapids, iowa
superhog88 Offline
superhog88  Offline
cedar rapids, iowa
do you remember what deck height measured at on your block before machine work was done and are you running a stock timing chain
Re: My bracket hemi build [Re: Triple Threat] #2106184
07/08/16 12:15 PM
07/08/16 12:15 PM
Renton Washington
Renton Washington
I do not remember deck height. Stock 6.1 timing chain.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2107898
07/11/16 02:26 PM
07/11/16 02:26 PM
Renton Washington
Renton Washington
8 More runs Saturday, New best ET of 10.21, 130.97mph 1.44 60'. 1100 Feet DA and 60% humidity, 29.59 Baro, 68 degrees.
Also got the win in Super Street (10.90 index)
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2111215
07/16/16 05:03 PM
07/16/16 05:03 PM
cedar rapids, iowa
superhog88 Offline
superhog88  Offline
cedar rapids, iowa
what rpm is the engine turning at the top end
Re: My bracket hemi build [Re: Triple Threat] #2112240
07/18/16 03:05 AM
07/18/16 03:05 AM
Renton Washington
Renton Washington
6900 shift and trap.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2112355
07/18/16 11:51 AM
07/18/16 11:51 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
I'm betting you are shifting below your peak HP rpm. Have you tried taking it to 7400-7500?
Re: My bracket hemi build [Re: STEFF] #2112373
07/18/16 12:32 PM
07/18/16 12:32 PM
Renton Washington
Renton Washington
I think there is more in it but I haven't started leaning on it yet. With a 30" slick and only 4.10's the car definitely wants more gear and RPM. I'm possibly changing the gear later this fall, I'll test first with a 28" tire and see how it likes that.
Only thing potentially holding it back up high would be the camshaft which is installed 5 degrees advanced at 103.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2112396
07/18/16 01:09 PM
07/18/16 01:09 PM
STEFF Offline
STEFF  Offline
Where is your converter hitting?
Re: My bracket hemi build [Re: Triple Threat] #2112476
07/18/16 02:45 PM
07/18/16 02:45 PM
Renton Washington
Renton Washington
It goes to 5800 on the brake and flashes similarly, it would probably like 6200+
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2112950
07/19/16 12:08 AM
07/19/16 12:08 AM
cedar rapids, iowa
superhog88 Offline
superhog88  Offline
cedar rapids, iowa
why did you use a stock chain and not one you could adjust
Re: My bracket hemi build [Re: superhog88] #2113208
07/19/16 12:31 PM
07/19/16 12:31 PM
Renton Washington
Renton Washington
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1948123/timing-chain.html
It's what was recommended basically. Might throw a Manley chain in it next time the engine is apart.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2115413
07/22/16 11:38 AM
07/22/16 11:38 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Steff, he is going to turn it up after the 500 mile break in period
Re: My bracket hemi build [Re: sixpackgut] #2115433
07/22/16 12:29 PM
07/22/16 12:29 PM
Renton Washington
Renton Washington
Grandma owned, only driven to church on Sundays.
Bracket racer problems... can't always change things if you want to win.
What do you boys shift at? Ray? Steff? anyone?
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2115435
07/22/16 12:30 PM
07/22/16 12:30 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I shift at 6700.
