Carpet #2100467
06/29/16 10:56 AM
06/29/16 10:56 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Finish putting in back seat last night so I'm going to lay carpet. Any hints,ideas that I should know ? ? Is it glued down anywhere ? ? Should I install the seat belts on hump 1st after installing carpet? ? 70 challenger auto on column.
thanks
Re: Carpet [Re: ct440rod] #2100983
06/30/16 09:00 AM
06/30/16 09:00 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
No ideas ? ?
Re: Carpet [Re: ct440rod] #2101100
06/30/16 01:33 PM
06/30/16 01:33 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
The original carpet in my grand pops 69 roadrunner was not glued down. If I were to put in new carpeting, I would work my way from installing the stuff on the center like the console and seat belts on the hump and then work my way out to the door openings.
inherited a 69 roadrunner from my grand pop.
Re: Carpet [Re: ct440rod] #2101140
06/30/16 02:50 PM
06/30/16 02:50 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Here's a good link from FABO on carpet installation. I think that it should help you out.
http://www.forabodiesonly.com/mopar/threads/for-those-looking-for-tips-on-carpet-install.118030/
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
