Re: Is this a "J" converter? [Re: Sport440] #210111
02/02/09 11:28 PM
02/02/09 11:28 PM
South Dakota
dakotahotrodder Offline
South Dakota
Here's some pics.........sorry for the delay. Mine is an old B&M "J". I took a picture of the part number. That number is on it along with a J in front of it. PTC also stamped their numbers in it when I had the snout replaced. Mine is a good footbrake converter with a fairly mild motor in a heavy car, not as good as my newer 8", but still good. They are very lazy in the 60'.
Re: Is this a "J" converter? [Re: dakotahotrodder] #210112
02/02/09 11:29 PM
02/02/09 11:29 PM
South Dakota
South Dakota
Re: Is this a "J" converter? [Re: dakotahotrodder] #210113
02/02/09 11:29 PM
02/02/09 11:29 PM
South Dakota
South Dakota
Re: Is this a "J" converter? [Re: dakotahotrodder] #210114
02/02/09 11:33 PM
02/02/09 11:33 PM
South Dakota
South Dakota
... and yes Paul Forte once told me they were made from a Cortina core, and anti-ballooning plates cannot be added, and they are no good with trans-brakes. The front pump also needs to be machined.
Re: Is this a "J" converter? [Re: dakotahotrodder] #210115
02/02/09 11:46 PM
02/02/09 11:46 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, They were designed to be a Soft hit vert for more consistant traction. mike
Re: Is this a "J" converter? [Re: Bob_Coomer] #210116
02/02/09 11:46 PM
02/02/09 11:46 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
A true, original J converter was used in a 66-72 Ford Cortina/Pinto/Capri with the 1.6L 4-banger.
Others may called them a J, but it depended on the what core was available at the time.
With all of the small cars available for the last 15 years, there ought to be good equivalent to these converters now.
Is it just me, or is the paint in your picture burnt?
8.30's @3400 lbs
