Front tube location? #209310
01/31/09 12:37 PM
01/31/09 12:37 PM
Canada
lenweiler Offline OP
Canada
When I add the front tubes, to stiffen the front, where should they be attached to on the front frame rail?
1. Behind the engine plate ontop of the frame rail? Not much room.
2. In front of the engine plate and ontop of the frame rail? It would have to be about 2" ahead to allow clearanc.
3. Or beside the engine plate, and side of the frame rail? Easiest location.
Damn! I dropped my change.............
Re: Front tube location? [Re: lenweiler] #209311
01/31/09 12:48 PM
01/31/09 12:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would drop it on the back edge(on part of the mount)
of the front motor plate
Re: Front tube location? [Re: MR_P_BODY] #209312
01/31/09 01:00 PM
01/31/09 01:00 PM
Canada
Canada
Ahh. The most difficult spot..
Re: Front tube location? [Re: lenweiler] #209313
01/31/09 02:14 PM
01/31/09 02:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if its easier to go forward then put it in up
there but if you do this you wont be abile to pull
the engine easily(the bars will be in the way)
Re: Front tube location? [Re: MR_P_BODY] #209314
01/31/09 03:45 PM
01/31/09 03:45 PM
Canada
Canada
I was concerned that your choice was a 'strength' issue. Apparently, y'all just looking out for me. This is temperary,so I'm looking to remove it when I put the cage in, and do it all over again. Thanks.
Re: Front tube location? [Re: lenweiler] #209315
01/31/09 10:23 PM
01/31/09 10:23 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Would the side work for you? That's what I did on my car because I didn't want the bars in the engine compartment.
Re: Front tube location? [Re: PLUM BAD] #209316
01/31/09 10:35 PM
01/31/09 10:35 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Just what I was thinking plum !
Re: Front tube location? [Re: VernMotor] #209317
02/01/09 12:53 AM
02/01/09 12:53 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Behind and mount the plate to it is my prefered choice:
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Front tube location? [Re: bigtimeauto] #209318
02/01/09 06:04 AM
02/01/09 06:04 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm not 100% sure but i think it was written in the mopar chassis book. the front bars should join the main chassis rail at the same point the front K frame bolts join to the chassis rail. this is where my front bars go & most well built mopars i've seen are there as well.
Re: Front tube location? [Re: PLUM BAD] #209319
02/01/09 07:27 AM
02/01/09 07:27 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
