Wheels that were screw drilled can use without screws? #209300
01/31/09 12:25 PM
01/31/09 12:25 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
Can you use wheels that were drilled with screws for slicks, on the street, without screws on regular radial tires? Would it affect the bead?
Re: Wheels that were screw drilled can use without screws? [Re: Blakcharger440] #209301
01/31/09 12:29 PM
01/31/09 12:29 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah you can use them without screws...but why would you want to if they're already drilled?
Re: Wheels that were screw drilled can use without screws? [Re: Blakcharger440] #209302
01/31/09 12:29 PM
01/31/09 12:29 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
sure i would just make sure there aren't any burrs on the bead from the holes being drilled
Re: Wheels that were screw drilled can use without screws? [Re: dizuster] #209303
01/31/09 12:32 PM
01/31/09 12:32 PM
Wichita,KS
Wichita,KS
Because they are going on my daily driver with street radials..... Have you drilled screws into street radial tires???
Re: Wheels that were screw drilled can use without screws? [Re: Blakcharger440] #209304
02/01/09 11:29 AM
02/01/09 11:29 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I see, they'll never hook hard enough to spin them on the rim anyway, you're right you probably don't need them...
