Page 1 of 2 1 2 >
#2082874 - 05/30/16 01:50 PM US Car Tool Chassis Kit + T56 Magnum Cuda Underside
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
Sharing the picture for other's reference of what torsion bar crossmember modifications are needed for a T56 Magnum as well as adding a USCarTool Chassis Kit.
I also added the forward 3x3" square from the torsion bar crossmember to the forward frame rail to help make up for the loss in material over the trans crossmember.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - Grandma Edition - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2082900 - 05/30/16 02:37 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
72Swinger Offline
Loc: Nebraska
Nice! Whats going on in the radiator support?
Mopar to the bone!!!
#2082907 - 05/30/16 02:56 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
67autocross Offline
Loc: Manitoba Canada
Do they make a kit to put a T 56 into s A body?
A new iron curtain drawn across the 49th parallel
#2082908 - 05/30/16 02:56 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 72Swinger]
5.7L Hemi, 6spd
Loc: Texas
Thats a US Car Tool part. Not the biggest fan of that one, but it's on there.
#2082909 - 05/30/16 02:58 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 67autocross]
5.7L Hemi, 6spd
Loc: Texas
Due to the amount of cutting that's needed, there isn't really a "kit" to use while maintaining torsion bars for any of the Mopar flavors.
I bought from SST, they have an Ebody and Bbody kit that comes with a lower mount, so the upper crossmember is up to you. If you remove the torsion bars in favor of coilovers, there is a substantial reduction in load going through that area.
...as far as Abodies go, you'd have to get with SST or American Powertrain.
#2085146 - 06/03/16 10:06 AM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Are you running the shifter in the as delivered location or rotating the plate so it sits forward? Might help clear the torsion bar crossmember...
Edited by ntstlgl1970 (06/03/16 12:12 PM)
#2085214 - 06/03/16 11:47 AM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
jcc Offline
No politics
Loc: Trumussia
And the rotisserie? work
Seeking more civil pastures
#2085375 - 06/03/16 03:59 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 67autocross]
72Swinger Offline
Loc: Nebraska
https://www.facebook.com/ToddRonRestorations/photos/?tab=album&album_id=347827735323636
ToddRon Restorations sells a kit.
#2085476 - 06/03/16 06:21 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: ntstlgl1970]
5.7L Hemi, 6spd
Loc: Texas
As installed. I don't think moving the shifter forward will help much, there is heavy interference with the transmission and crossmember. If you have to cut the majority of the crossmember out, you might as well stick the shifter where you want it.
That upper crossmember was lowered for final install, this photo was right after welding it together.
#2085477 - 06/03/16 06:22 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: jcc]
5.7L Hemi, 6spd
Loc: Texas
It's not termite-proof, but it is cheap!
#2085508 - 06/03/16 06:53 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
72Swinger Offline
Loc: Nebraska
Does that shifter location land in the factory console hole?
#2085512 - 06/03/16 06:55 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 72Swinger]
5.7L Hemi, 6spd
Loc: Texas
Doubtful, its centered on the hump and i think the factory 4spd is offset to the drivers side.
#2085531 - 06/03/16 07:18 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I already did major surgery on my upper crossmember for the 518, hoping not much more is needed for the t56, thanks for the photos
Edited by ntstlgl1970 (06/03/16 07:21 PM)
Edit Reason: Because
#2085654 - 06/03/16 10:36 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
68cuda440 Offline
Loc: Plano, Texas
I was able to get mine through the console, had to move it an inch or so.
http://www.forabodiesonly.com/mopar/attachments/dsc03071s-jpg.1714709321/
http://www.forabodiesonly.com/mopar/attachments/p82a04281s-jpg.1714712338/
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
#2085658 - 06/03/16 10:45 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 72Swinger]
68cuda440 Offline
Loc: Plano, Texas
ToddRon's kit is for use with the "Ford" version of the T56 Magnum and the matching Quicktime bellhousing for a small block. I started with his kit and modified it heavily to get it to work with a "GM" version of the T56 Magnum and the matching bellhousing for a big block. APT recommended to me to go the with the combo I did for some reason due to the clutch, I don't remember the details. The ToddRon kit is quite stout and does require considerable fabrication even as is for a small block.
http://www.forabodiesonly.com/mopar/attachments/p82a0231-jpg.1714678367/
http://www.forabodiesonly.com/mopar/attachments/p82a0246-jpg.1714680787/
#2085663 - 06/03/16 10:51 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
68cuda440 Offline
Loc: Plano, Texas
#2104580 - 07/05/16 10:20 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
71sat440 Offline
Loc: Willow Grove PA
Holly crap is that a wooden whirly jig? How the heck does it work, and is there a build thread?
#2104583 - 07/05/16 10:23 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 71sat440]
5.7L Hemi, 6spd
Loc: Texas
Ahyup, whirly wooden jig. Only a half whirly wooden jig though.
No build thread, just an afternoon with some screws, some wood, and a skill saw.
#2105202 - 07/06/16 06:37 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
71sat440 Offline
Bottom pic looks like it has more additional bracing against the rear rails.
Where you able to tilt that yourself?
My car is a bare sandblasted shell.
I've been dreading the day I go to weld in the uscartool frame connecters I got last year at Carlisle.
I can't afford a 1k+ for a rotisserie and have come to accept I will be welding these things on my back in complete misery.
This is one of the coolest home depot solutions I've seen. Just wondering how you achieve a controlled flip.
#2105223 - 07/06/16 07:04 PM Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda]
boydsdodge Offline
Loc: Toronto, Ont, Canada
Great Tilt stand.
Great work.
Page 1 of 2 1 2 >
25,636 Registered Members
195,696 Topics
Air cleaner contoured entry criticality?
by Moparmal
12/17/18 03:14 AM
1971 Dodge Charger
by tomsjack
12/17/18 02:58 AM
76 Dodge D300 custom sleeper flat bed
by theraif
12/17/18 12:49 AM
Milodon oil pan
by StageIII
12/16/18 10:58 PM
