Roller lifter specs #208213
01/29/09 09:39 PM
01/29/09 09:39 PM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Does anyone know the cup dimensions of the Comp Cams 829 solid roller lifter?
Re: Roller lifter specs [Re: Plumcrazyracing] #208214
01/29/09 09:51 PM
01/29/09 09:51 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
if your looking for the ball diameter, it's 5/16.
Re: Roller lifter specs [Re: TS3303] #208215
01/29/09 09:56 PM
01/29/09 09:56 PM
Central Coast
P
P
Central Coast
would the raduis be a 5/32?
Re: Roller lifter specs [Re: Plumcrazyracing] #208216
01/29/09 10:22 PM
01/29/09 10:22 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
yes
Re: Roller lifter specs [Re: TS3303] #208217
01/30/09 01:27 AM
01/30/09 01:27 AM
Central Coast
P
P
Central Coast
Thank you.
