main and rod bearing question?? #207905
01/29/09 06:08 PM
01/29/09 06:08 PM
Ohio
fiddlestix Offline OP
Ohio
I bought a 440 based 493 stroker kit from an individual and these bearings came with it. Mains are Federal Mogul part #119M and the rods are Speed Pro part #7135CH. Will these bearings be OK on a mostly street driven car or will they have a short life span. From what I have read they won't last as long as some other bearings and aren't the best choice for a street-strip car. Any help would be appreciated!!!!
Re: main and rod bearing question?? [Re: fiddlestix] #207906
01/29/09 08:34 PM
01/29/09 08:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'm not familiar w/ the rod bearings you mentioned but the FM 119M mains are perfectly acceptable for a street / strip application. I don't know where you're getting your info from...
Re: main and rod bearing question?? [Re: fiddlestix] #207907
01/29/09 09:30 PM
01/29/09 09:30 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The bearings should never see metal to metal contact. No bearing will last if they do. Even at shut down and sitting there is enough oil film to cover while pressure builds and tey will have oil before the gauge shows pressure.
Re: main and rod bearing question?? [Re: MoparforLife] #207908
01/29/09 09:51 PM
01/29/09 09:51 PM
North West,Ohio
SSDA3426 Offline
SSDA3426  Offline
North West,Ohio
I Have used BOTH Bearings with no problems on Street Strip Applications...They will be Fine as long as you have .002-.004 Clearance....
SS
Re: main and rod bearing question?? [Re: SSDA3426] #207909
01/29/09 10:19 PM
01/29/09 10:19 PM
Upper Midwest
Upper Midwest
SS
IMO - that is pretty loose.
Re: main and rod bearing question?? [Re: MoparforLife] #207910
01/29/09 10:28 PM
01/29/09 10:28 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
actually the 119M is a good choice. It's a 3/4 groove bearing which IMO is the best of the 3 options as it has almost full bearing surface for loading and the extra oil supply.
