anyone know anything about these tool steel lifters? #207878
01/29/09 06:03 PM
01/29/09 06:03 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline OP
VanishPt  Offline OP
V
Re: anyone know anything about these tool steel lifters? [Re: VanishPt] #207879
01/29/09 06:21 PM
01/29/09 06:21 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
A direct replacement for the Schubeck ceramic-foot lifter and hardened to 64 Rockwell, these lifters provide the strength and toughness necessary to operate at both higher RPM and higher spring pressures.
I dont know about that part, with the poor (motor eating) quality of Joes lifters when he went to H--- in a handbag im not sure if id even print that....
I would like to hear from one who has used them though.....sorta looks like the nascar coated lifters...
Ive been wondering when alot of the coatings and such used in nascar and others would trickle down to being used other places.
Re: anyone know anything about these tool steel lifters? [Re: VanishPt] #207880
01/29/09 06:56 PM
01/29/09 06:56 PM
AndyF Offline
AndyF  Offline
Trend builds super high quality stuff so I'd trust them. If you're thinking of going that way you might want to talk to Mike Jones at Jones Cam Design. He has a lot of experience with tool steel lifters and can grind cams that will work with them.
Re: anyone know anything about these tool steel lifters? [Re: AndyF] #207881
01/29/09 07:04 PM
01/29/09 07:04 PM
V
VanishPt Offline OP
VanishPt  Offline OP
V
wonder if you could use these with a flat cam that would approach the performance of a mild street roller? And would you have to break them in like a normal lifter?
Re: anyone know anything about these tool steel lifters? [Re: VanishPt] #207882
01/29/09 08:02 PM
01/29/09 08:02 PM
AndyF Offline
AndyF  Offline
Well if you match them up with some high ratio rocker arms you could definately get pretty good results.
Re: anyone know anything about these tool steel lifters? [Re: AndyF] #207883
01/29/09 08:29 PM
01/29/09 08:29 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I didn't see the price
