Roll cages ???
#207841
01/29/09 05:50 PM
01/29/09 05:50 PM
Posts: 576 Somewhere Over the Hill
Mr. Dodge
I have a question on roll cages and Under hood bars
My car should be a low 10 sec to high 9's my question is do I need the the under hood bars??
I've heard people state that it helped them and some people said it slowed them down quite a bit...
What should I do...I hate to say I'm gonna have this professionally installed and I don't want something thats gonna slow the car down and I dont want to have extra holes in the car if I have to cut them out..
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison)
69 Hemi Coronet R/T
70 456 Dart Swinger
Re: Roll cages ???
[Re: Mr. Dodge]
#207842
01/29/09 05:54 PM
01/29/09 05:54 PM
Posts: 189 Newark, OH
springers340dart
Newark, OH
i think it'll help keep the frontend stiffend up and not twist as easy but i'm wanting to think that if your quicker than 10.00 you have to have a full cage and all but not sure.
Re: Roll cages ???
[Re: springers340dart]
#207843
01/29/09 06:27 PM
01/29/09 06:27 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
They stiffen up the chassis,they are not required as part of the roll cage.They should be used when inner fenders and firewall are altered and modified.
Re: Roll cages ???
[Re: Mr. Dodge]
#207845
01/29/09 06:38 PM
01/29/09 06:38 PM
B G Racing
Eighty Four, PA
My Inner fender walls are still stock.... This car is a 50/50 car it will see as much drag time as street time
The stiffer the better,we seen most cars that are tied together with a 10,12 or 14 point cages usually 60' better and if your combo is prone to wheelstands we recommend the front bars.
Re: Roll cages ???
[Re: B G Racing]
#207846
01/29/09 07:06 PM
01/29/09 07:06 PM
Mr. Dodge
Here are the Engine Specs: 451 6pac Stroker Stage II ported Edelbrock 84cc heads, 2.14 Intake and 1.81 Exhaust valves. Stage II street/strip port flowed 285 cfm @550 lift. The 400 block has been square decked and line honed and sonic checked. 440 Crank forged steel unit. Compression is 10.95:1 .060 Keith Black KB251 pistons, Rods, factory LY rods w/ ARP rod bolts. Cam shaft is a Lunati 273/ 279, Lift .578/ .585 @110 cl and 1.6 ratio roller rockers. The motor is fully balanced to within .2 tenths of a gram. Mopar 6 pack intake and carbs Motor made 585 hp and 550 foot lbs torque..... Dana 60 w 4:56 and a Powr-Loc 325X50X15's on a 10 in Convo Pro Centerline rim 18 spline 4-speed
69 Hemi Coronet R/T
70 456 Dart Swinger
Re: Roll cages ???
[Re: TS3303]
#207851
01/30/09 02:00 AM
01/30/09 02:00 AM
Mr. Dodge
TS3303 Nope nothing valuable just a Dart
69 Hemi Coronet R/T
70 456 Dart Swinger
Re: Roll cages ???
[Re: TS3303]
#207852
01/30/09 08:57 AM
01/30/09 08:57 AM
Posts: 82 Illinois
hswhemi1
Illinois
Mr Dodge, adding the front down bars will not hurt anything and actually help unibody mopars greatly. They help tie the font section to the back half through the cage. The added weight of those two bars is nothing. Unless this is a rare valuable car add them.
blown, no offense as your work is very nice but all those fancy bends have greatly reduced the structural integrity of the cage and created failure points if something serious should happen. I also question if you will see any benefit at all with your front bars as there will be very little longitudinal loading of them. It appears in the picture that any load will be transfered into flexing and a radial load where they are welded to the plate on the door frame. To be effective the compression and tension loads should be transfered longitudinally through the bar to the cage.
What the pictures of Blown EFI don't show are how the forward bars are tied into the inner fenderwell,the firewall and the A-Pillar all to be welded which in turn act as a gusset thus absorbing and dispersing any and all loads placed on them and not allowing flex into the radius of the bend plus tied into the cage tubes as well NOT welded to a plate on the door frame,that is a 16 gauge cap to cover the slightly oversize hole that was needed to get the tube fit into the car and tied into the windshield tube.The cap will be fully tig welded to the A-Pillar 100% plus around the tube 100%.The reason those were placed where they were is to retain the heater box as this car is an 1800 hp street car,and those did need to be there to tie everything front to back together as it should be.THANX
Re: Roll cages ???
[Re: B G Racing]
#207854
01/30/09 11:01 AM
01/30/09 11:01 AM
Posts: 82 Illinois
hswhemi1
Illinois
Forward bars should be tied to the frame rails to be of any structural value and tied into the pillar uprights to maximize the stiffness through out the chassis.Tieing the bars to to the inner fender or attaching them to the firewall serves little purpose.Bolt in applications are permitted in minimal requirment classes for safty but do little to stiffen the chassis.Every bar should serve a purpose for structural intrgrety or rigid strength.To place bars that don't offer integrity or stiffness is only going to be cosmetic and a waste of time and effort.
The forward bars are attached in 5 locations,the framerail where they should be the windshield bar where they should be and in 3 other locations to help them in deflection because of the abnormal install of them.We don't just put tubes in a car for cosmetics,I'm WELL aware of the structure of a racecar!
Re: Roll cages ???
[Re: hswhemi1]
#207855
01/30/09 11:18 AM
01/30/09 11:18 AM
Posts: 1,417 Chicago, IL
blownEFI
Chicago, IL
The pictures I posted are not very good, I apologize for that, they don't fully show everything. I will get some better pictures once everything is final welded and I'm sure that will clear up some of the questions.
To be clear, Dennis would not be doing the front bars this way on a RACE car, but this being a street car I originally wasn't even going to have any front bars at all but Dennis convinced me to at least put something there to help stiffen the chassis. Will those front bars be as resistent to a head-on crash as conventionally placed ones, maybe not, but then that's a compromise I'm making. If it were really up to Dennis he would build a 25.2 cage for this car because, strictly from a power-to-weight ratio perspective, that's what it really should have. But again, I'm wanting to retain a street car look so I'm not going to that level with the cage. All of this being said, I think Dennis is doing a great job given the parameters he is working within.
Again, my apologies for the poor pictures, they don't really do Dennis work justice, and I will get some better ones and post them up.
"These go to eleven", Nigel Tufnel
Re: Roll cages ???
[Re: hswhemi1]
#207856
01/30/09 11:19 AM
01/30/09 11:19 AM
B G Racing
Eighty Four, PA
Comments were general statments and not referring to your set up.Anyone looking close can see how you have tied your cage to the pillars and rails,even with your unconventional routing of your tubes.I don't see anywhere where I referred to your set up.Most chassis builders try and triangulate bars and supports as much as possible.Like you mentioned you have multipule attaching points to compensate for your radial loading,so obiviously you have an understanding of what your doing.That you posted your pictures opens the topic for discussion,positive or negative.That I posted my comments and in no way refrenced anything about your setup didn't require your remarks to me.
Re: Roll cages ???
[Re: dvw]
#207858
01/30/09 06:15 PM
01/30/09 06:15 PM
B G Racing
Eighty Four, PA
I like to tie mine into the shock tower as well. Doug
Same here Doug,we tie the shock tower right to the front bars on most every car with stock inner fenders and especially those that have been cut for fenderwell headers and other clearence issues.
