Front and rear window trim clip questions, 70 Charger #2077130
05/20/16 02:49 PM
05/20/16 02:49 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Can someone help me on location measurements for the top of the rear window,
I haven't enough holes showing after the bodywork to figure out the rest?
Also on the sides of the front window I have two upper holes showing,
but it looks as if there should be a lower one on each side for symmetry.
I was supplied 10 of the large clips for the front bottom, but only can see 8 recesses,
just extras??
Thanks everyone, Joe
Re: Front and rear window trim clip questions, 70 Charger [Re: jlatessa] #2077276
05/20/16 08:04 PM
05/20/16 08:04 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Well I got the back window squared away with member's referencing some threads, Thanks
Also, when the bodywork was done the two endmost recesses on the windshield's bottom were mudded over.
I was able to grind out the filler and re-drill the holes, all is well there now.
Only question left; do the front pillars get two or three clips each?
I can see what looks to be the remnants of two Phillips headed screws near the bottom of the A pillar,
is that where the third clip goes or is that that where the little L shaped retainer at the corner gets fastened??
Thanks guys, Joe
