Roll bar to roll cage #207553
01/29/09 10:49 AM
01/29/09 10:49 AM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Expected weight increase from going from 6 point roll bar 1 3/4. To 10 point roll cage 1 5/8 mild steel.
76 Duster work in progress
Re: Roll bar to roll cage [Re: Edge] #207554
01/29/09 01:53 PM
01/29/09 01:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m interested it this myself as I`m gonna have to cross that path at some point+ what about cost including cert....Sorry to hijack.
Re: Roll bar to roll cage [Re: Edge] #207555
01/29/09 02:03 PM
01/29/09 02:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm pretty sure you need to go .134 wall and if so
its 2.133 lbs/ft.... take a guess at how many feet
you will need
Re: Roll bar to roll cage [Re: MR_P_BODY] #207556
01/29/09 02:13 PM
01/29/09 02:13 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
thanks for the information Mr P. That is heavy stuff. I am going .134 wall for the tubing. Any idea what 1 3/4 .135 wall weighs a foot ?
Hoop and down bars around 18 feet total. Close to 40 lbs I guess less the weight the lighter wieght of the 1 5/8 tubing of the rest of the cage.
Re: Roll bar to roll cage [Re: Edge] #207557
01/29/09 02:32 PM
01/29/09 02:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2.328 lbs/ft for 1 3/4 .135 wall. Heres what I use
for the weight
http://www.steel-pipes-tubes.com/steel-pipe-weight-calculator.html
Re: Roll bar to roll cage [Re: MR_P_BODY] #207558
01/29/09 05:02 PM
01/29/09 05:02 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
thanks that is exactly what I was looking for
Re: Roll bar to roll cage [Re: Edge] #207559
01/29/09 05:23 PM
01/29/09 05:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
In mild steel .134" is used if it electric welded tubing. If you use D.O.M., you can use .120". It is more costly.
Doug
