dear engine building friends... #207456
01/29/09 12:52 AM
01/29/09 12:52 AM
organ
maximum entropy Offline OP
organ
i'm building a 500 tall deck medium effort stroker for a friend, and the kit provided me with clevite ms-1795 v main bearings. according to summit they're vandervells, or a reasonable facsimile. what do you guys think about these? they're half grooved, which i don't care for, but if you guys say they're good, i'll use 'em. shouldn't see more than 7000 rpm.
Re: dear engine building friends... [Re: maximum entropy] #207457
01/29/09 04:03 AM
01/29/09 04:03 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
7000 rpm??? swap them for full groove.
Re: dear engine building friends... [Re: maximum entropy] #207458
01/29/09 11:36 AM
01/29/09 11:36 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Those are soft bearings that are especially made for racing. Don't let the half groove shouldn't scare you. It's a good bearing. They will not last as long however. I use that bearing for mild supercharged engines because of the embedability.
Re: dear engine building friends... [Re: Mopar_Rich] #207459
01/29/09 12:41 PM
01/29/09 12:41 PM
organ
organ
this engine will definitely be race only. these bearings are expensive, that's for sure! i have no experience with half grooved bearings in a race application, hence my paranoia.
Re: dear engine building friends... [Re: maximum entropy] #207460
01/29/09 01:47 PM
01/29/09 01:47 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
For a normally aspirated RB bracket engine where I'd want the bearings to outlast the rings, I'd use the MS2233HG main bearing, Calico coated.
Re: dear engine building friends... [Re: Mopar_Rich] #207461
01/29/09 02:19 PM
01/29/09 02:19 PM
organ
organ
i've used those before with good results. thanks for the input!
Re: dear engine building friends... [Re: maximum entropy] #207462
01/30/09 12:30 AM
01/30/09 12:30 AM
I'm not a fan of V series bearings.
i'd recommend the clevite MS1277HG if it's a later block that will accept the larger thrust surface.
