Re: Pump Gas Hemis
[Re: Hot 340]
#2073991
05/15/16 06:23 PM
05/15/16 06:23 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
What pump gas? Non ethanol? 91 or 93? 11.1 with aluminum heads is about the max in the REAL world IMO.
Mopar to the bone!!!
Re: Pump Gas Hemis
[Re: 72Swinger]
#2073998
05/15/16 06:34 PM
05/15/16 06:34 PM
Posts: 3,395 Pa
Hot 340
Pa
What pump gas? Non ethanol? 91 or 93? 11.1 with aluminum heads is about the max in the REAL world IMO. whats your combination? Are you seeing detonation at 11?
Re: Pump Gas Hemis
[Re: Hot 340]
#2074034
05/15/16 07:33 PM
05/15/16 07:33 PM
72Swinger
Nebraska
No sir but mine is one of those 16 spark plug, flat top piston NOT A REAL Hemi.....Hemi's. It runs like a missle with 23* of advance. I shouldnt even be wasting your time by commenting lol! Are you building a new combo or wanting to make an existing combo work on pump gas? Is E85 an option?
Re: Pump Gas Hemis
[Re: 72Swinger]
#2074042
05/15/16 07:51 PM
05/15/16 07:51 PM
Posts: 3,395 Pa
Hot 340
Pa
No sir but mine is one of those 16 spark plug, flat top piston NOT A REAL Hemi.....Hemi's. It runs like a missle with 23* of advance. I shouldnt even be wasting your time by commenting lol! Are you building a new combo or wanting to make an existing combo work on pump gas? Is E85 an option? New combination/new parts with old design gen 2 stuff. E85 is out for me, no place close by that sells it. 😟
Re: Pump Gas Hemis
[Re: Hot 340]
#2074049
05/15/16 07:57 PM
05/15/16 07:57 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
What pump gas? Non ethanol? 91 or 93? 11.1 with aluminum heads is about the max in the REAL world IMO. whats your combination? Are you seeing detonation at 11? I ran 11.6:1 in my 484 with no issues for years. I have a 605 hemi now, and I am right around 11.0-11.1:1 with no issues. The Hemi's are very resistant to having issues with detonation. I would be very comfortable running 12:1 on 93 and watching my timing and tune up. What we use around here is E10, so until they get rid of it, that's what I am running mine on. I would not run any lower than 11:1 on pump gas with a hemi. If your building it, build it for 12:1 with .027 head gaskets, and switch to thicker ones if you have to.
Re: Pump Gas Hemis
[Re: Dragula]
#2074107
05/15/16 09:14 PM
05/15/16 09:14 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
Just finished and dyno'd my 528 with a true 10.5:1 and it almost made 840 hp and 671 TQ.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Pump Gas Hemis
[Re: 6PKRTSE]
#2074122
05/15/16 09:31 PM
05/15/16 09:31 PM
Posts: 3,395 Pa
Hot 340
Pa
Just finished and dyno'd my 528 with a true 10.5:1 and it almost made 840 hp and 671 TQ. I'm guessing on pump gas. What timing and cylinder pressure?
Re: Pump Gas Hemis
[Re: Hot 340]
#2074140
05/15/16 09:48 PM
05/15/16 09:48 PM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sorry didn't catch the Hemroid part.
Re: Pump Gas Gen 2 Hemis
[Re: Hot 340]
#2074319
05/16/16 02:10 AM
05/16/16 02:10 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
I've built and dyno tested several different stock Mopar iron headed pump gas 426 type motors, 434 C.I., 3.91 stroke and 4.150 stroke motors for the same customer. All of them where right at 10.5 to 10.8 to 1 compression ratio and ran fine with CA pump swill back in the early 2000s I built the same customer a D5 alumimun headed 526 C.I. motor with a stock OEM Mopar cross ram with stock OEM Holley SS carbs., it struggle to make 50 HP more on the DTS engine dyno than the 4.150 stroke motor did with the new heavy Mopar iron replacement heads and a stock 1966 inline intake manifolds and stock 1966 AFB Carbs did That motor had a little over 12.5 to 1 compression, I probally should have treid it also on CA 91 octane pump swill
[Re: Hot 340]
#2074398
05/16/16 10:29 AM
05/16/16 10:29 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
[Re: Hot 340]
#2074407
05/16/16 11:05 AM
05/16/16 11:05 AM
Posts: 11,994 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I bought my 540 reciprocating assembly and cam from Ray Barton. He spec'd the CR @ 10.5 for this aluminum headed street/strip motor. I asked him about more comp since I have ran 11:1 in my aluminum headed 499 wedge for years with no problems. He said there wasn't enough additional power for a primarily street driven engine to warrant the extra hassles.
Master, again and still
Re: Pump Gas Hemis
[Re: cudadoug]
#2074529
05/16/16 02:31 PM
05/16/16 02:31 PM
Posts: 95 NW INDIANA
ta3834bbl
NW INDIANA
Yes, I am very interested in your combo as well. I love to learn new stuff that works. Just finished and dyno'd my 528 with a true 10.5:1 and it almost made 840 hp and 671 TQ. Care to share the combo?
67 Dart GT Convertible 273 68 Barracuda 383 68 Roadrunner 383 4spd 1 '01 Ram 2500 4x4 diesel 2 '02 Rams 1500 4x4's 4.7s 3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4 Oh, and a 03 Grand Cherokee and an '00 durango
Re: Pump Gas Hemis
[Re: Hot 340]
#2074582
05/16/16 04:15 PM
05/16/16 04:15 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
our pump swill here is 85 octane, so I kept my 572 at 9.5 to one, that way I know that I can run any gas anywhere. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Pump Gas Hemis
[Re: Dragula]
#2074803
05/16/16 11:04 PM
05/16/16 11:04 PM
Posts: 3,395 Pa
Hot 340
Pa
What pump gas? Non ethanol? 91 or 93? 11.1 with aluminum heads is about the max in the REAL world IMO. whats your combination? Are you seeing detonation at 11? I ran 11.6:1 in my 484 with no issues for years. I have a 605 hemi now, and I am right around 11.0-11.1:1 with no issues. The Hemi's are very resistant to having issues with detonation. I would be very comfortable running 12:1 on 93 and watching my timing and tune up. What we use around here is E10, so until they get rid of it, that's what I am running mine on. I would not run any lower than 11:1 on pump gas with a hemi. If your building it, build it for 12:1 with .027 head gaskets, and switch to thicker ones if you have to. any trouble with 12:1 on a hot day? That would be my concern.
