Anyone use the Speedmaster aluminum heads #2072300
05/12/16 10:45 PM
05/12/16 10:45 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
Saw these aluminum BB heads on ebay made by Speedmaster for $1100 a pair, anyone use these, any issues
Re: Anyone use the Speedmaster aluminum heads [Re: 75dusted] #2072431
05/13/16 02:57 AM
05/13/16 02:57 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
popcorn
Re: Anyone use the Speedmaster aluminum heads [Re: 52savoy] #2072435
05/13/16 03:08 AM
05/13/16 03:08 AM
You might Google it
Re: Anyone use the Speedmaster aluminum heads [Re: 75dusted] #2072443
05/13/16 04:09 AM
05/13/16 04:09 AM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
Yes, they are called "Sidewinders" same casting sold by Todd at Moparts Racing, Hughes, CPPA and ProMaxx.
Re: Anyone use the Speedmaster aluminum heads [Re: 75dusted] #2072530
05/13/16 11:36 AM
05/13/16 11:36 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
for the price i would get the promaxx heads from jegs.
i've read that they have a very nice facility in Alabama that does the finish work.
Speedmaster = ProComp [Re: krautrock] #2072613
05/13/16 02:32 PM
05/13/16 02:32 PM
dogdays Offline
dogdays  Offline
NO NO NO!!!!!!!!!!!!!!does not equal Promaxx or Sidewinder!!!
The Speedmaster heads are the ProComp heads, ProComp changed their branding about two years ago. It's no secret, ProComp announced it back then.
The Sidewinder and I believe Promaxx and probably some other names, are better heads from a different Chinese facility. The owner has actually been on this board to explain that.
But the way the marketplace works is that you get online and you can order up a pallet or container or sometimes as few as one pair of quite a few different heads from China, they're not hard to find. When they get here you can call them whatever you can program a CNC machine to spell. Or possibly buy enough and get a custom label cast into the heads.
I believe you can even buy replacement Cummins 6BT blocks.
Anyway, just be aware that ProComp is now called Speedmaster. Most of the part numbers are even the same starting with a PC.
R.
Re: Speedmaster = ProComp [Re: dogdays] #2072667
05/13/16 03:48 PM
05/13/16 03:48 PM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
Hughes is selling them as Speedmasters, they sure do look the same as the Sidewinders..
http://www.hughesengines.com/Index/produ...mp;partid=30290
Re: Speedmaster = ProComp [Re: 75dusted] #2072710
05/13/16 04:39 PM
05/13/16 04:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Look at the outside edge on the deck surface below the outer row of head bolts, there are two notches on the corner on the sidewinder and not on the procomp. That is the easy quick way to see if you are getting the good one or the junk
Re: Speedmaster = ProComp [Re: Banzaiii67] #2072713
05/13/16 04:43 PM
05/13/16 04:43 PM
dogdays Offline
dogdays  Offline
Re: Speedmaster = ProComp [Re: HotRodDave] #2072762
05/13/16 05:30 PM
05/13/16 05:30 PM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
I'll take your word for it as I haven't seen either up close, but gosh there sure do look the same. Could you point out this notch, because i'm not seeing it.
Sidewinders
Speedmasters
Also it has been established the PROMAXX Head is the same as the Sidewinder head, never was the Speedmaster or Procomp brought up
What I woul like to say is Promaxx 440 head and Todd Sidewinder head are very nice casting and accurate machining. The material is A356.2, elements such as Fe, Ti, Mg, and Si was under control. Which help the aluminum have better microstructure and lead to better physical performance such as hardness, elongation. The advantage of the casting is the intake and exhauste port are very smooth. Much smoother than RPM heads. Because the casting is using special fine sands in intake and exhaust port. The machining is using modern technology with 4 axises CNC machines. The combustion volume, the position tolerance was under strict control. The machine tolerance is 3/1000 mm. There is someone do it better, it's AFR. AFR tolerance is 1/1000 mm in key positions. In a words, the heads were made by OE standards with is same as GM present cylinder heads production standard. Both Promaxx and Todd is doing great job to make the better 440 cylinder head better. More people try it, more people will be happy."
Re: Speedmaster = ProComp [Re: 75dusted] #2072784
05/13/16 06:10 PM
05/13/16 06:10 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
So it looks like speedmaster uses either of the cheap castings. Those are the same as the sidewinder, this is the other cheap casting
http://www.ebay.com/itm/Mopar-Chrysler-BB-383-440-265cc-74cc-As-Cast-Bare-Aluminum-Cylinder-Head-/181870711810?hash=item2a5856d402:g:vmQAAOSwT6pV1ShD&vxp=mtr
Even easier way to tell em apart is the heart shaped chamber in the pro-comp or as it is labeled in this pic a "speedmaster".
Re: Speedmaster = ProComp [Re: HotRodDave] #2072829
05/13/16 07:21 PM
05/13/16 07:21 PM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
Not the same Speedmaster's I'm talking about.
Also, the Ebay sellers name isn't "Speedmaster" but the location is Rialto California, where Speedmaster HQ is.
http://www.ebay.com/itm/Mopar-Chrysler-B...d-/351582057596
Mopar Chrysler BB 361 440 210cc 70cc Performance Aluminum Wedge Cylinder Head
Brand: Speedmaster
Part Number: JM-MP-210-70
Part Type: Cylinder Heads
Cylinder Head Style: Bare
Cylinder Head Material: Aluminum
Cylinder Head Finish: Natural
Combustion Chamber Volume (cc): 75cc
CNC-Machined Combustion Chamber: No
Intake Runner Volume (cc): 210 cc
Exhaust Runner Volume (cc): 70cc
CNC-Machined Intake Runner: No
CNC-Machined Exhaust Runner: No
Intake Port Shape: Rectangular
Intake Port Location: Standard
Exhaust Port Shape: Square
Exhaust Port Location: Standard
Intake Valves Included: No
Intake Valve Diameter (in): 2.100 in.
Exhaust Valves Included: No
Exhaust Valve Diameter (in): 1.810 in.
Valve Springs Included: No
Damper Spring Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Rocker Arm Studs Included: No
Rocker Arms Included: No
Rocker Arm Nuts Included: No
Guideplates Included: No
Valve Cover Mounting Style: Perimeter Bolt
Accessory Bolt Holes Drilled: Yes
Intake Valve Angle: 15 Degree
Exhaust Valve Angle: 15 Degree
Valve Guides Included: Yes
Valve Guide Material: Bronze
Valve Seats Machined: Yes
Valve Seat Machine Style: 3-angle
Valve Seat Material: Hardened
Steam Holes Drilled: No
Quantity: Sold individually.
