aircleaners and filters #207189
01/28/09 09:27 PM
01/28/09 09:27 PM
PA, USA
moparpilot1 Offline OP
PA, USA
has anybody ever dyno tested a dual snorkle air cleaner to a open element air cleaner and a k&n filter to a stock fram filter and what were the results and on what type of engine or on the drag strip thanks
Re: aircleaners and filters [Re: moparpilot1] #207190
01/28/09 11:53 PM
01/28/09 11:53 PM
I have not dyno testes a dual snorkel to open element but I have tested a K&N six pak aircleaner element to a Fram paper element on back to back A-B-A tests on a DTS engine dyno with dual wide bans, no measureable HP or torque differences , there was a small AFR leaning out with the Fram paper element I also tested single elenent versus two elements stack on top of each other and saw a 8 hp increase with two on a 600 hp motor
