Page 5 of 8 1 2 3 4 5 6 7 8
Re: `56 Plazakota [Re: SattyNoCar] #2069266
05/08/16 12:13 PM
05/08/16 12:13 PM
Caldwell, Idaho
67R/T4speeder Offline OP
Caldwell, Idaho
Originally Posted By Satilite73
Originally Posted By 67R/T4speeder
Spindles arrived
What brand are those?
Belltech
Re: `56 Plazakota [Re: 67R/T4speeder] #2070061
05/09/16 01:50 PM
05/09/16 01:50 PM
Caldwell, Idaho
Caldwell, Idaho
I got some welding done Saturday morning when no body is around, shut the doors and turn the tunes up and weld away.
Re: `56 Plazakota [Re: 67R/T4speeder] #2070177
05/09/16 04:48 PM
05/09/16 04:48 PM
moparx Offline
moparx  Offline
looks good and that definitely won't go anywhere ! up [now hopefully, it was done with the clip in the right spot ! whistling] just funnin ya ! looks good as i said before !
beer
Re: `56 Plazakota [Re: moparx] #2070220
05/09/16 06:02 PM
05/09/16 06:02 PM
Caldwell, Idaho
Caldwell, Idaho
beer
Thanks, I think I wore out two tape measures checking and double check then check two more time LOL
Re: `56 Plazakota [Re: 67R/T4speeder] #2071608
05/11/16 06:55 PM
05/11/16 06:55 PM
Caldwell, Idaho
Caldwell, Idaho
Dakota rear axle is 63" drum to drum
Plaza rear axle is 60" drum to drum
Drats!! was hoping to use Dakota
Whats in yours John?
Re: `56 Plazakota [Re: 67R/T4speeder] #2071625
05/11/16 07:17 PM
05/11/16 07:17 PM
dogdays Offline
dogdays  Offline
You just need wheels with the right backspacing. 1.5" more...
Late 300 or Charger or Mustang would be where I'd start.
R.
Re: `56 Plazakota [Re: dynamite] #2071631
05/11/16 07:28 PM
05/11/16 07:28 PM
Caldwell, Idaho
Caldwell, Idaho
Originally Posted By dynamite
Has an 8 3/4 rear, 3:55 gears but have a 2:76 complete center section I put in for road trips..senf some pics of your ride ,, good luck Larry
Do you know what your 8 3/4 is out of Larry? Seems a b-body will be very close in width drum to drum.
Re: `56 Plazakota [Re: dogdays] #2071634
05/11/16 07:29 PM
05/11/16 07:29 PM
Caldwell, Idaho
Caldwell, Idaho
R.
So keep with the Dakota and use offset wheels?
Re: `56 Plazakota [Re: 67R/T4speeder] #2071635
05/11/16 07:31 PM
05/11/16 07:31 PM
Caldwell, Idaho
Caldwell, Idaho
Just don't want to be stuck with having to buy too much of a modern wheel if that make sense.
Re: Plazakota [Re: 67R/T4speeder] #2071645
05/11/16 07:46 PM
05/11/16 07:46 PM
Caldwell, Idaho
Caldwell, Idaho
The Dakota axle. She's got some miles on her but I can rebuild if it's width will work . Spring pads are off a bit but that's no biggie to weld new ones.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2071889
05/12/16 03:25 AM
05/12/16 03:25 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Are those Dakota wheels on the rear axle now? Original Dakota wheels have the wheel mounting flange about an inch behind the front tire mounting surface (I'll post a picture of a Dakota wheel, front silver wheel is Dakota, rear black wheel is not.)
Early (66-70) B body rear is the most narrow 8 3/4 rear axle (other the the A body 8 3/4 that has the wrong wheel bolt pattern).
Other options: Jeep Cherokee, 73 & newer A Body ( disc brake car has 4 1/2" bolt pattern).
Non Mopar: Ford Explorer 8.8 has 4 1/2" bolt pattern, newer ones have disc brakes, and limited slip with 3:73 gears is pretty common, and with the correct rear end yolk, you can bolt the small Mopar u joint up to it.
Re: `56 Dodge modern front end swap advice [Re: poorboy] #2071987
05/12/16 12:16 PM
05/12/16 12:16 PM
Caldwell, Idaho
Caldwell, Idaho
Yes they are Dakota stock wheels on the axle pic, I took them off and measured mounting flange to flange and came up with 63" and Plaza is 60" .
Nice looking car you building smile love that roof line
Re: `56 Plazakota [Re: 67R/T4speeder] #2072056
05/12/16 02:40 PM
05/12/16 02:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'65-'67 B-body, 59 1/2" drum-to-drum with perches moved inboard to 41". 15" X 8" wheels with no offset fit easy.
Re: `56 Plazakota [Re: 67R/T4speeder] #2072109
05/12/16 04:35 PM
05/12/16 04:35 PM
Caldwell, Idaho
Caldwell, Idaho
Thanks John for answering my question twice for me, ooops my bad.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2072451
05/13/16 05:26 AM
05/13/16 05:26 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
[/quote]
Nice looking car you building smile love that roof line [/quote]
Finished product>
Re: Plazakota [Re: 67R/T4speeder] #2073388
05/14/16 06:32 PM
05/14/16 06:32 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
Here are some WMS measurements for those in need. NO, it is not complete and any additions will be appreciated.
http://www.qualityengineeredcomponents.com/?page_id=1023
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: Plazakota [Re: poorboy] #2073885
05/15/16 03:38 PM
05/15/16 03:38 PM
Caldwell, Idaho
Caldwell, Idaho
Finished product>[/quote]
My Dakota has two silver and two black wheels , is this standard?
Fun looking car
Re: Plazakota [Re: 67R/T4speeder] #2074237
05/15/16 11:40 PM
05/15/16 11:40 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My car had 4 silver wheels, but 2 wheels had junk tires that wouldn't hold air. The 2 black wheels had good tires that held air, and they were larger tires, so they had to go on the back, right? By the time the car hit the street, someone gave me 4, old, matching, Michelin tires. That was when I discovered the rear wheels were also a 1/2" wider then the front wheels. I finally painted the wheels earlier this spring, (after 4 summers on the road), just before I put the new tires on, all 4 wheels are now blue.
The car is a blast to drive. With the 3.9 V6, 5 speed it gets good MPG, and I can drive it all day for around $20! The car is light enough I could get a chirp out of 3rd with the old Michelin 235 x 75 x 15 tires, its got a 3:55 limited slip 8 3/8 Dakota axle (haven't tried it yet with the new tires that got put on last week).
The car is just fast enough to be entertaining without collecting tickets. There is a guy around here that says "Its more fun to drive a slow car fast, then it is to drive a fast car slow." I agree with him.
My wife and I enjoy going for rides in it, we took it on a 135 mile ride today. The car has heat & defrosters and insulation (no AC, we are not AC fans, windows down cruising for us) and is very comfortable riding between about 40 degrees and 90 degrees. Memorial Day weekend we are off on a 2200 mile vacation covering 7 states with this car. The car runs down the Interstate just fine, but on our trip, we are taking 2 lane highways for a slower more relaxing trip. Gene
Re: Plazakota [Re: poorboy] #2074375
05/16/16 08:40 AM
05/16/16 08:40 AM
moparx Offline
moparx  Offline
which direction are you heading on your trip gene ?
beer
Re: Plazakota [Re: moparx] #2074429
05/16/16 11:55 AM
05/16/16 11:55 AM
Caldwell, Idaho
Caldwell, Idaho
beer
popcorn
