Needs Some early Spring Track Advice now... :0) #207155
01/28/09 09:17 PM
01/28/09 09:17 PM
U.S.
moparniac Offline OP
U.S.
Well some of you know I have made some good changes to my car...... its a 3800lb e body and need some good advice as last time at track I failed and changed to much crap at once and paid for it... anyhow....
3800lb and best MPH was 124.43 what ET should have the car ran setup properly then ???
CHANGES FOR THIS YEAR...... nothing has been tested yet on new combo
11" Shelf Coan to Custom 9" .. same a a9seccuda runs (chip)
SS Springs to Caltracs / Split monos
CE on all 4 corners to Rancho 9 ways and calvert fronts
3.5"'s of Travel to 5"'s
26" tire to 28" fronts
28" Dot's to 30" rear Dot's
No more front swar bar
8 3/4 (3.91) to Dana 60 (4.10's)
Stage 3 Port Eddy Rpms 2.14*1.81 to MCH Max Wedge 2.19*1.81 Indy EZs
10.92 to 11.1 compression
Same Roller cam 248/254 @ .050 will change by end of season!
I have a full asst of jets now current BIGS dominator is 90 squared
what et and MPH can I expect now set up properly
and also some track day tuning advice and tips...
Mopar Performance
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207156
01/28/09 09:36 PM
01/28/09 09:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I would think 124 mph would be upper 10`s and as far as where to start, you may be visiting the track a few times to figure that out. If you can, chassis tune that puppy first and get the afr`s close to save a bunch of money and time or even damage if its lean. Then start w/ proper tire pressures, leave rpm`s and shift points.....then of course there`s shock settings, squirteres, final jetting etc. Get the idea?
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207157
01/28/09 09:39 PM
01/28/09 09:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Stage 3 Port Eddy Rpms 2.14*1.81 to MCH Max Wedge 2.19*1.81 Indys
It should have gone 10.65 with your MPH.
What was your old 60', with your new conv and the
4.10 you should be 60' a good bit better(take you
gain in the 60' and multiply it by 1.5 for the ET change)
Work on the 60' then work on mid track... top end
tuning is MPH.... remember 1 thing at a time... write
it down... if you have time back up the run to verify
Re: Needs Some early Spring Track Advice now... :0) [Re: MR_P_BODY] #207158
01/28/09 10:31 PM
01/28/09 10:31 PM
U.S.
U.S.
thx P yes 1 thing at a time for sure..... i am gonna start logging everything!
Mopar Performance
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207159
01/28/09 10:42 PM
01/28/09 10:42 PM
Q
Quicktree Offline
Quicktree  Offline
Q
at 3800#s 124mph may not get you in the 10s imo.
Re: Needs Some early Spring Track Advice now... :0) [Re: Quicktree] #207160
01/28/09 11:29 PM
01/28/09 11:29 PM
U.S.
U.S.
the car came on strong after the 1/8 it seemed like... dunno I am not a track expert.. does this show anything? im pretty sure the 11" converter sucked..... lol
330 1/8 MPH 1000 MPH
4.791 7.34 96.7 9.556 124.43
Mopar Performance
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207161
01/28/09 11:49 PM
01/28/09 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Remember chassis is ET, HP is your MPH
Re: Needs Some early Spring Track Advice now... :0) [Re: Quicktree] #207162
01/29/09 12:43 AM
01/29/09 12:43 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Cant see how it couldnt? I ran 11.33 at 117.72 at 3800 lbs. 124 would get me a high .70 at worst.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Needs Some early Spring Track Advice now... :0) [Re: Von] #207163
01/29/09 06:39 AM
01/29/09 06:39 AM
U.S.
U.S.
sorry.. 10.96 is my best but pbody is right cause my 60fts have always sucked IMO and i feel i should have went quicker... the new converter and caltracs alone should help this
do you guys think I should tune my chassis first and then mess with jetting ... I messed up bad last time and did both same day... lol
Tires were et streets
I had so much bad luck in 1 day!
MSD chips were coming on 500 rpm early
broke a kmotion k 1000 spring last pass
kept bouncing of rev limiter
pin for secondaires broke off some how and had to zippy tied the crap (external sec.)
Alternator went out on me also and was running off battery kept recharging it off a jump..
plus I am just a track rookie i guess...
this was all in one day
with my new setup do you think I can get a 10.3 once dialed in..
Mopar Performance
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207164
01/29/09 07:46 AM
01/29/09 07:46 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you have the power, it's just going to take a little tuning to get where you want to be I think. I would set the jetting to factory specs and make a pass. you can then check the jetting and get an idea of what the chassis is going to do.
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207165
01/29/09 10:03 AM
01/29/09 10:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That 10.3 might be a bit much, I think a 10.5 might be about it
Re: Needs Some early Spring Track Advice now... :0) [Re: Quicktree] #207166
01/29/09 01:02 PM
01/29/09 01:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, here are some times from my Challenger last year running at 3750#s w/ similar MPH.
60 / 660 ET / 660 MPH / 1320 ET / 1320 MPH
1.481 / 6.776 / 100.17 / 10.720 / 124.12
1.479 / 6.768 / 100.34 / 10.696 / 124.72
1.474 / 6.742 / 100.85 / 10.662 / 124.69
It's all about the 60-ft.
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207167
01/29/09 01:36 PM
01/29/09 01:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
After looking at your changes again, with the head
work and bigger valves.... I think you will run a
10.4 at 128...... if you can max out the package.
But its hard to say if your engine was near max to
give you the currant 124 mph(if you were FAT or LEAN)
you werent max HP, you made enough HP to run 124,
see what I mean
Re: Needs Some early Spring Track Advice now... :0) [Re: MR_P_BODY] #207168
01/29/09 04:45 PM
01/29/09 04:45 PM
U.S.
U.S.
see what I mean
when i did pull a plug the track day at the end p the plugs looked good to me.... with the BIGS 90 squared setup... plugs were autolite 3922's then... I have a pic of the plug somewhere... bRB. lol
thx for the help guys
brad H I have always admired your times and combo.. I think its one of the most effective combos on the site..
My car is a 72 Challenger btw
Mopar Performance
Re: Needs Some early Spring Track Advice now... :0) [Re: moparniac] #207169
01/29/09 04:54 PM
01/29/09 04:54 PM
U.S.
U.S.
I forgot to mention I have put in a header evac system also... I cant find the pics of my plugs but the burn looked good... not lean at all....
Mopar Performance
