Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!!
[Re: BradH]
#2073500
05/14/16 08:50 PM
05/14/16 08:50 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
How small the bowls really are in the unported head isn't all that apparent in the pic, and the bowls in the ported heads were even more filled in.
Brad, If you look at the area on the top of the ported heads, where the pads are on the intake runners, you can see all the indications of the core shift....... The head bolt hole, valve cover bolt hole, head bolt recess next to the ports, etc. It was just as bad, maybe worse, in the bowls of those heads. Maybe you could get a pic of that area of the head. You'll see the unported head doesn't have that issue.
[Re: BradH]
#2073826
05/15/16 01:30 PM
05/15/16 01:30 PM
Posts: 25,892 United Socialist States of Ame...
tboomer
Brad...Mine were early heads and came out pretty good. You gonna get that thing done before I head to the drag strip in the sky?? Also you have lots of good info there...
[Re: BradH]
#2074411
05/16/16 11:10 AM
05/16/16 11:10 AM
tboomer
Brad...I never made a full recovery from that incident in 2013. On the other hand I just found my receipt for my Victor standard port heads. I bought them Jan.4th 2012.
[Re: fast68plymouth]
#2115495
07/22/16 01:59 PM
07/22/16 01:59 PM
Triple Threat
Renton Washington
Brad, I guarantee you won't wear out that porting LOL, might go through a couple keyboards though.
[Re: Triple Threat]
#2115496
07/22/16 02:01 PM
07/22/16 02:01 PM
Posts: 20,156 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Brad, I guarantee you won't wear out that porting LOL, might go through a couple keyboards though. Ouch. Lol
