Innovate LM-1 O2 sensor problem
#2065200
05/01/16 12:28 PM
05/01/16 12:28 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
I am using an inovate LM1 air/fuel meter but it has an error code 4 pump open. The instructions say to check the cable and do a heater recalibration, which I have done.
Still the same error code 4, pump open. So I am thinking of replacing the O2 sensor. Is there commonly available sensor that I could pick up at a parts store rather than order one from inovate ? Or a better solution than replacing the O2 sensor? Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Innovate LM-1 O2 sensor problem
[Re: Hemi_Joel]
#2065211
05/01/16 12:47 PM
05/01/16 12:47 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
BOSCH 17014
if you are getting it from Advance auto parts, order online, pick up at store, use TRT30 code as a "promotional code" you will end up paying around $40
Joe
Without Data, you’re just another guy with an opinion.
[Re: Hemi_Joel]
#2065412
05/01/16 06:57 PM
05/01/16 06:57 PM
Hemi_Joel
Minnesota
THanks, Joe!
Scamp, sorry I don't know. I've never had that happen.
[Re: Hemi_Joel]
#2065632
05/02/16 12:23 AM
05/02/16 12:23 AM
Posts: 7,506 Az
Crizila
Az
Still the same error code 4, pump open. So I am thinking of replacing the O2 sensor. Is there commonly available sensor that I could pick up at a parts store rather than order one from inovate ? Or a better solution than replacing the O2 sensor? Thanks, Joel Did you check all your grounds? I think I have a good used spare if you are interested.
Fastest 300
