Re: pros and cons of solid flat tappet vs solid roller
[Re: mopar dave]
#2062872
04/27/16 06:32 PM
04/27/16 06:32 PM
Posts: 4,457 Washington
madscientist
Washington
It's 2016. 7k might as well be at idle.
Some day, it will occur dawn on some of us that RPM is just as important as torque, maybe more so.
If you can't spin a 511 7k may as well park it. Guys leave way too much on the table with tight converters, no gear and tow truck RPM.
[Re: nss guy]
#2062895
04/27/16 07:03 PM
04/27/16 07:03 PM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
@ Madscientist
Generally maybe but a lot heads today have the flow capabilities to push the Torque and HP peaks past where a lot of people feel safe pushing a stock block RB motor. Also not everybody runs MW heads on their 511's so the port flow/velocity is somewhat of an RPM "check valve" limiting the RPM no matter where the valvetrain could go.
and (opinions vary I guess but) many if not most 493-511's usually wind up dropping into heavy B and E bodies with automatics and mid 3 series carriers, so not everybody wants or needs to turn them much past 6200-6500 to have a fun and formidable torque monster. Ron's (383Man's) 63 B has a comparably mild Street driven 493 with ported EZ MW's and runs 10.70's through the muffs, not too shabby and he's not revving all that high. so I guess just because you can doesn't mean you should...or even need to.
[Re: Streetwize]
#2062900
04/27/16 07:13 PM
04/27/16 07:13 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
And your stock blocks will thank you for it by lasting a lot longer
[Re: DrCharles]
#2063110
04/28/16 12:14 AM
04/28/16 12:14 AM
Posts: 1,845 Tampa
DusterDave
Tampa
The big con with a flat tappet cam is, if your break-in procedure wasn't done perfectly, and/or you are not using the correct oil (which is getting harder to find locally anymore) I'm pretty sure those little bottles of ZDDP (zinc) are still available? you run the risk of some lobes going round, and really messing up your crank, bearings and piston skirts. It happened to me, and many, many others. I can see the wear particles from the cam & lifters being thrown into the cylinder bores by splash, but how would they get through the oil filter to the crank and bearings? Nobody's mentioned the old "Mini-Express" mushroom cam/lifters P3690588 (316 adv. @ 0.654) and there's a bigger one 328, 0.690. Lifters are a PITA to change but the few people who have run one have had good things to say about the performance. I think it's around 270 duration @.050. A lot cheaper than a roller setup... So, you say you can't afford one of them high dollar roller cam setups like the rich Ricky racers have? No problem, bro, just do what Joe Dirt did!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: mopar dave]
#2063135
04/28/16 12:37 AM
04/28/16 12:37 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Who said anything about revving it to 7 grand? The LS7 was just an example.
@ mad scientist, there literally millions of beehive springs in use (and some pretty high horsepower high revving engines) with an almost next to nothing failure rate. IF you broke so many springs.. something else is at foot.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: mopar dave]
#2063210
04/28/16 05:05 AM
04/28/16 05:05 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Im glad to see a few flat tappet users out there having good results. I'm really not too worried about the amount of power loss with a flat tappet at this point as this will be 90% street driven. Just a pain to break in. The roller worries would be with the valve spring and lift rebuilds. I used to have mine rebuilt every 3yrs which was about 2000miles and maybe 50 passes. I dont think I said that I do use the Comp EDM lifters and as said i have had great results with no problems so far in the almost 5 years my eng has been together. Ron
[Re: B3422W5]
#2063211
04/28/16 05:12 AM
04/28/16 05:12 AM
383man
Balt. Md
I will give you great advice. Call Dwayne Porter, go with his suggestion, and have him order you a cam. He knows 100% what he is doing and that takes the guesswork out of it. I have personal experience using his help, and the cams worked perfect. That is great advice as its what I did. I was considering a roller but after talking to Dwayne and telling him how much I plan to drive on the street he recomended that I would most likely be happier with a solid flat tappet which I am. He speced my custom grind solid flat tappet and I could not be happier with the results and great service it has given me. Dwayne is a Pro who does this every day and knows what he is doing and I would say he is as good as anyone out there. Heck I have been an auto tech all my life and been around hotrods and muscle cars most of my life and feel I know cams pretty well. But I dont do it (Performance cams and heads) for a living every day and I dont run my engines on dyno's like he does when he builds them so he gets to see what has worked best and he can test his work which helps him know what works good and best. You cant go wrong calling Dwayne and talking to him. Good luck with your build which ever cam you decide on. Ron
[Re: Streetwize]
#2063212
04/28/16 05:17 AM
04/28/16 05:17 AM
383man
Balt. Md
@ Madscientist
and (opinions vary I guess but) many if not most 493-511's usually wind up dropping into heavy B and E bodies with automatics and mid 3 series carriers, so not everybody wants or needs to turn them much past 6200-6500 to have a fun and formidable torque monster. Ron's (383Man's) 63 B has a comparably mild Street driven 493 with ported EZ MW's and runs 10.70's through the muffs, not too shabby and he's not revving all that high. so I guess just because you can doesn't mean you should...or even need to. Thank you for the kind words Wize. I foot brake to about 2k on the line and shift about 6200 and trap around 6400. Thats when I look at the tach because I wont lie most of the time I shift when it feels right but its about 6200. Ron
[Re: mopar dave]
#2063374
04/28/16 02:01 PM
04/28/16 02:01 PM
Posts: 13,356 Marion, South Carolina [><]
an8sec70cuda
[Re: Airwoofer]
#2063435
04/28/16 03:37 PM
04/28/16 03:37 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
As for the beehive springs, I saw the springs on the Burick Monte works on one day at the track. They are really thin bee hives which blew me away as that thing probably has about an inch of valve lift.
Say what? Don't know what you thought you saw, but it was no bee hive spring. What you saw was a Pac triple spring with 450lbs of seat pressure. And the cam is about 1.200 on the lift
