440-1'S FORGIVE ME FOR MY IGNORANCE #206017
01/27/09 05:11 PM
01/27/09 05:11 PM
CHANDLER, AZ
512 VALIANT Offline OP
CHANDLER, AZ
SERIOUSLY, I'VE READ SEVERAL POSTS AND I AM IGNORANT TO DIFFERENCE BETWEEN 440-1 AND SAY PROCOMP OR EDDY HEADS ECT. WILL 440-1 HEADERS WORK WITH PROCOMP OR EDDY HEADS. I BELIEVE THE FLANGE BOLTS ARE ALL THE SAME??? WHAT OR IS THERE AN ADVANTAGE???
Re: 440-1'S FORGIVE ME FOR MY IGNORANCE [Re: 512 VALIANT] #206018
01/27/09 05:32 PM
01/27/09 05:32 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
header flanges are the same but they ports on the heads are raised about 3/8 of an inch so not in the stock location.
The intake valve is moved and you need special rocker arms that are .800 offset.
The 440-1 flow about 80cfm out of the box better than those heads and are capable out flowing them big time with fully ported.
They are in a different league, big step up from Procomp/Eddies.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: 440-1'S FORGIVE ME FOR MY IGNORANCE [Re: WadeMetzinger] #206019
01/27/09 05:46 PM
01/27/09 05:46 PM
CHANDLER, AZ
CHANDLER, AZ
SO WOULD 440-1 HEADERS WORK ON PROCOMP OR EDDY HEADS??? - THE FLANGES ARE THE SAME, BUT WOULD THE PORTS LINE UP??
Re: 440-1'S FORGIVE ME FOR MY IGNORANCE [Re: 512 VALIANT] #206020
01/27/09 05:56 PM
01/27/09 05:56 PM
Tulsa, Ok
Tulsa, Ok
yes, but if they were build for 440-1 head they will be setup for a higher exhaust port location so on procomp/eddie heads they will hang down 3/8 - 1/2 lower on the bottom of the car but that shouldn't be a problem on a race car.
Re: 440-1'S FORGIVE ME FOR MY IGNORANCE [Re: WadeMetzinger] #206021
01/27/09 06:03 PM
01/27/09 06:03 PM
NC
440Jim Offline
440Jim  Offline
NC
Depending on the header design, they may also hit the steering box, oil pan (due to angle), etc.
Re: 440-1'S FORGIVE ME FOR MY IGNORANCE [Re: WadeMetzinger] #206022
01/27/09 06:14 PM
01/27/09 06:14 PM
CHANDLER, AZ
CHANDLER, AZ
THX, BECAUSE THE CAR CAME W/ WHAT I WAS TOLD WERE 440-1 HEADERS (CUSTOM MADE TO WRAP AROUND CAGE ECT.) JUST WANTED TO MAKE SURE THEY WOULD WORK W/ MY PROCOMP HEADS (ENGINE IS AT MACHINE SHOP SO I CAN NOT TEST FIT THEM - I JUST MOCKED THEM UP ON STOCK HEADS AND 440 BLOCK) - CUSTOM HEADERS LIKE THE THESE ARE HIGH DOLLAR AND THAT WILL SAVE ON SOME $$$.
