Re: I need help deciphering codes (magnum)
[Re: west]
#2059791
04/22/16 04:21 PM
04/22/16 04:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
P1521–INCORRECT ENGINE OIL TYPE
When Monitored: Engine Running. Set Condition: Using the oil pressure, oil temperature and other vital engine inputs the PCM can determine the engine oil viscosity. Incorrect viscosity will effect the operation of the MDS by delaying cylinder activation .
Possible Causes INCORRECT ENGINEOIL TYPE ENGINE OIL CONTAMINATION ENGINE OIL Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. Diagnostic Test
1. ACTIVE DTC NOTE: Review the customers oil change history. Ensure the customers is using the correct engine oil viscosity. If the incorrect oil is being used, change the oil, using the correct engine oil viscosity. Ignition on, engine off. With the scan tool, read DTCs. Is the DTC active at this time?
Yes
Go to 2
No
Test Complete.
2. ENGINE OIL NOTE: If set along with P1521, repair any engine oil pressure or temperature DTCs first before continuing.
The following conditions must be checked.
OEM recommended oil viscosity is being used. Customer is following the oil change schedule. Check the engine oil for contamination. (i.e., fuel and/or engine coolant) Internal engine condition that may effect oil pressure.
Were any of the above conditions found?
Yes
Repair as necessary. Perform the POWERTRAIN VERIFICATION TEST.
No
Change the engine oil using the correct oil viscosity. Perform the POWERTRAIN VERIFICATION TEST.
If this was an early production vehicle I'd say check with a dealer on a TSB that was issued for this. But since you just had the engine rebuilt I suggest that you:
1. Verify oil viscosity used. 2. If incorrect oil was used, drain and refill with proper weight oil. 3. Insure that your oil pressure sensor has not been damaged during the repair work.
[Re: west]
#2059801
04/22/16 04:36 PM
04/22/16 04:36 PM
Supercuda
About to go away
About to go away
up yours
Duuno, my SIL had an issue with his '10 Ram and wrong oil was one of the codes, with several VVT related codes as well. Dealership wanted to bend him over for new VVT stuff to teh tune of $1200.
We changed the oil per the TSB that addresses these codes and viola it was all good.
Apparently, these engines are very sensitive to oil viscosity and old oil gets thicker.
I would start there myself, probably needs it anyway.
