Re: !!!
[Re: fast414]
#2057935
04/19/16 10:05 PM
04/19/16 10:05 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Hey guys!! ....quick question. Can I get the fuel out of my gas tank by disconnecting the fuel line at my carb and cranking the engine ?? (Harbor Freight has a real cheap 'transfer pump'...
Re: !!!
[Re: RSNOMO]
#2057941
04/19/16 10:12 PM
04/19/16 10:12 PM
RapidRobert
I'd get a T (some hardware store NPT pipe nipples (probably 1/8 NPT) and a T would would work fine & black fittings are slightly cheaper than galvanized fittings) & T it into the neoprene fuel line between pump and the carb and get 6ft of 5/16" neoprene fuel line & run it to a big jug & idle it & it'll be empty in minutes. EDIT oops! just hit me that the gas must be bad so you would not want to be introducing it into the carb!
Re: !!!
[Re: dvw]
#2058206
04/20/16 08:48 AM
04/20/16 08:48 AM
Posts: 5,094 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
This ^^^^^ Years ago on the race car we had an extra fuel cell cap with a valve stem inserted to drain the fuel. Works good for everything except a small amount in the end...maybe a quart or so...
...FAFO...
Re: !!!
[Re: RSNOMO]
#2058234
04/20/16 09:52 AM
04/20/16 09:52 AM
Posts: 43,458 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Hey guys!! ....quick question. Can I get the fuel out of my gas tank by disconnecting the fuel line at my carb and cranking the engine ?? (Harbor Freight has a real cheap 'transfer pump'... I just used one of those HF pumps last week, love the smell of 10 year old fuel...
JB Rhinehart, Realist
A-Body's RULE!
