Re: Wilwood brakes installed [Re: MR_P_BODY] #205801
01/27/09 10:38 PM
01/27/09 10:38 PM
Monroeville, OH
midnight maniac Offline
Monroeville, OH
I am having the same problem with the first hit being soft then they pump up after that.Last year I did the wilwood up grade on all four wheels. I have the 4 piston setup all around. I am using the factory master cylender which I was told is 1 1/16". Wilwood told me this was suffice. My pads also look like the retract a little to far. I was wondering if you could use a residual or not with disc?
'69 Road Runner 528 B-1 headed pump gas. Best 9.39 @ 142. 3320#
Re: Wilwood brakes installed [Re: midnight maniac] #205802
01/27/09 10:43 PM
01/27/09 10:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It will hold some line pressure in the line, might
be enough so you dont have to hit the pedal a second
time to have it feel firm but you have to make sure
they are pulling back off of the rotor
Re: Wilwood brakes installed [Re: MR_P_BODY] #205803
01/27/09 11:34 PM
01/27/09 11:34 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
You should have a 1-1/8" MC with aftermarket 4 wheel disc brakes. WW pistons going back too far, first pump on the pedal feels soft - hmmmm.............I wonder if they copied Aerospace's fully retractable piston design. I do not remember any older WWs having this issue.
Re: Wilwood brakes installed [Re: Lil Demon] #205804
01/27/09 11:43 PM
01/27/09 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill is running the 1 1/8 master and he has the problem
also thats why I'm thinking they might be able to
use the residual valve
