Re: Exhaust system on e-body
[Re: racerx]
#205762
01/27/09 01:26 PM
01/27/09 01:26 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Go to Napa and get 3.5" mandrel bent sections (Walker) and cut/weld them together.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: racerx]
#205763
01/27/09 01:44 PM
01/27/09 01:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Anyone on here have pic.'s on there e-bodys exhasut system?I'm looking 2 build a 3 1/2" system and trying 2 get a ideal on how 2 run the pipes around the crossmember Do u all just use the prebent pipes/cut and weld?I'm lost Thax....
When you go under the crossmember you can flatten the tube(no more than 50% of the diameter) to give you some added ground clearance.... this wont hurt the surface area of the tubing
[Re: dthemi]
#205765
01/28/09 03:04 AM
01/28/09 03:04 AM
Posts: 4,049 Mo.
racerx
Mo.
Here's mine. 4 inch all the way from collector to tip. Just put the mufflers behind the cross member.
dthemi what type headers u runing?(custom,tti,hookers ) Thax u all 4 you'r response
