Exhaust system on e-body #205761
01/27/09 11:52 AM
01/27/09 11:52 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone on here have pic.'s on there e-bodys exhasut system?I'm looking 2 build a 3 1/2" system and trying 2 get a ideal on how 2 run the pipes around the crossmember Do u all just use the prebent pipes/cut and weld?I'm lost Thax....
Re: Exhaust system on e-body [Re: racerx] #205762
01/27/09 01:26 PM
01/27/09 01:26 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
Go to Napa and get 3.5" mandrel bent sections (Walker) and cut/weld them together.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Exhaust system on e-body [Re: racerx] #205763
01/27/09 01:44 PM
01/27/09 01:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you go under the crossmember you can flatten
the tube(no more than 50% of the diameter) to give
you some added ground clearance.... this wont hurt
the surface area of the tubing
Re: Exhaust system on e-body [Re: MR_P_BODY] #205764
01/27/09 01:51 PM
01/27/09 01:51 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Here's mine. 4 inch all the way from collector to tip. Just put the mufflers behind the cross member.
Re: Exhaust system on e-body [Re: dthemi] #205765
01/28/09 03:04 AM
01/28/09 03:04 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
dthemi what type headers u runing?(custom,tti,hookers ) Thax u all 4 you'r response
Re: Exhaust system on e-body [Re: racerx] #205766
02/02/09 10:59 PM
02/02/09 10:59 PM
Central Pa.
Cloned_Cuda Offline
Cloned_Cuda  Offline
Central Pa.
Just a
