need gaskets for my tunnel ram #205745
01/27/09 11:01 AM
01/27/09 11:01 AM
mo
moparbud Offline OP
moparbud  Offline OP
mo
guys where do you get your gaskets for your tunnel ram intakes mine is a mopar performance i need the two that goes under the top half
Re: need gaskets for my tunnel ram [Re: moparbud] #205746
01/27/09 11:31 AM
01/27/09 11:31 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Comes in a blue tube. Says 'RTV' on it or something like that on it.
Re: need gaskets for my tunnel ram [Re: moparbud] #205747
01/27/09 02:09 PM
01/27/09 02:09 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
gasket paper and trimmer
WAXER
Re: need gaskets for my tunnel ram [Re: QWK_ENUF] #205748
01/27/09 04:23 PM
01/27/09 04:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
Thats the way I make them, I also use Hylomar as the gasket sealant
Re: need gaskets for my tunnel ram [Re: Cab_Burge] #205749
01/27/09 05:47 PM
01/27/09 05:47 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
When I had mine, I tried to find pre-made. None were found, so I got a thick sheet of material and made my own. The ones I did find for other intakes were more than the sheet anyway...
Re: need gaskets for my tunnel ram [Re: Cab_Burge] #205750
01/27/09 05:59 PM
01/27/09 05:59 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Personally I would just use the Hylomar.
Re: need gaskets for my tunnel ram [Re: RodStRace] #205751
01/27/09 06:00 PM
01/27/09 06:00 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
... so I got a thick sheet of material and made my own...
Same here for my M1 TR.
I also cut my gaskets a little wider than the narrow factory gaskets that got sucked in and caused MAJOR vac leaks.
Re: need gaskets for my tunnel ram [Re: RedRam] #205752
01/27/09 07:56 PM
01/27/09 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I havent seen those gaskets since MP quit selling them,
I just make my own
Re: need gaskets for my tunnel ram [Re: MR_P_BODY] #205753
01/27/09 08:10 PM
01/27/09 08:10 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
what? another tunnel ram freak??? either make'em or use sealer.
Re: need gaskets for my tunnel ram [Re: tjmarcus1] #205754
01/27/09 08:38 PM
01/27/09 08:38 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi
fel pro has a nice small roll part no. 3157 just got one at NAPA, it's about .027 thick and 10in. x 26in. nice stuff, I made some hemi intake gaskets out of it.
Russ
Re: need gaskets for my tunnel ram [Re: old_racer] #205755
01/27/09 08:46 PM
01/27/09 08:46 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
ok thanks guys i will make them
