408 broken in, now I need help to pick headers, #205592
01/27/09 01:04 AM
01/27/09 01:04 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Howdy
I just had a transmission snafu and since I'm already on jackstands with no transmission for a little while I figure it's a good time to replace the rusty banged out leaking 20 year old hooker comp's that are on the car.
I want to get the most out of the engine that I can, without sacrificing drivability and ease of maintainance for max power. I can currently barely change plugs #5+#7, but it's not too hard. I don't want to have to pull the new headers to change my spark plugs. My old comp headers hang a little low, which is fine with me, and also capture the steering linkage on the driver's side, which is ok too. I do like being able to change the mini- starter without pulling the headers.
My setup:
I have a '72 4 speed demon. The motor is a .030 over 360 with a 4" crank and eddy heads. .525 inch lift cam with 230/237 duration at .050. 10.25:1 compression. Mostly for street use, but 13 seconds rowing a 4 speed would be nice (haven't tried yet...) I have 4.10 gears, 28"x10.5" tires. The carb is a 750dp with man. choke and a single plane intake.
Here are the choices I'm considering:
Hooker comp 1 5/8"x34" $180 black $409 ceramic
-these are probably what I already have
Hooker Super comp 1 5/8"x35" $435 black
Hooker Super comp 1 3/4"x38" $509 black
TTI step 1 5/8" to 1 3/4" $630 chrome $704 ceramic/thermal barrier
So- from barbeque black small tubes to big tubes to step tubes with chrome or fancy coatings, from $180 to $705. Big differences!
The questions are: how much will I be leaving on the table with the small headers on a healthy stroker, how much of a pain in the butt will the big ones be to install and work around later, and are the TTI's worth it in terms of ease of installation and spark plug clearance etc.
I didn't find much with the search option, so please lets hear it, I don't want to regret whatever decision I end up making!
Kevin
Which headers for my 408?
single choice
Votes accepted starting: 01/27/09 12:00 AM
You must vote before you can view the results of this poll.
Re: 408 broken in, now I need help to pick headers, [Re: radar] #205593
01/27/09 01:51 AM
01/27/09 01:51 AM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
I voted for the TTI's, the fit without massaging
will be better, less hassels with install.
Phil Saran Parker, Colorado
Re: 408 broken in, now I need help to pick headers, [Re: Phil Saran] #205594
01/27/09 02:08 AM
01/27/09 02:08 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I vote Dougs. Same fit as tti. tti's are basically a copy of them with some small differences.
Steps aren't going to make a big difference IMO.
You'll be chopping up your z bar with either Dougs or tti to get it to fit. The down leg will hit really bad. They have on every manual trans car with either header I've ever worked on.
Bonus, coated Dougs are about $530
Dougs pictures:
http://www.forabodiesonly.com/mopar/showthread.php?t=40645
PS your car should run low 12's, maybe high 11's REALLY easy.
Re: 408 broken in, now I need help to pick headers, [Re: RobX4406] #205595
01/27/09 03:08 AM
01/27/09 03:08 AM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
TTI has 17/8 headers for standard head soon to released.
Re: 408 broken in, now I need help to pick headers, [Re: 71Pan] #205596
01/27/09 07:43 AM
01/27/09 07:43 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you're considering the hooker comps, I'd look at the headmans. similar fit, but they're cheaper and made in the USA (hooker comps are made in mexico)
on my M body I can change the full size starter without dropping the hedmans, and I can change all the spark plugs, too. the #5 wire I had to modify the boot so it wouldn't sit on the header though.
2017 Grand Cherokee Overland
Re: 408 broken in, now I need help to pick headers, [Re: patrick] #205597
01/27/09 08:09 AM
01/27/09 08:09 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Heddman Hustlers, 1 7/8".
Re: 408 broken in, now I need help to pick headers, [Re: justinp61] #205598
01/27/09 08:27 AM
01/27/09 08:27 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I would not go with as big as 1 7/8's. We dynoed ours with a dual plane and a bigger 255/.57" cam, and while 2" headers were 10 hp better at peak, they were dogs below 3000 rpm compared to the cheapo 1 5/8's. I would recommend either the TTI's or the Hooker 1 3/4's.
Plynouth VIP '67 TT IC EFI
Re: 408 broken in, now I need help to pick headers, [Re: 71Pan] #205599
01/27/09 09:29 AM
01/27/09 09:29 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
It's about time. The last time I talked to TTI, I asked why they
didn't offer the 1 7/8" headers with 3 1/2" collectors.............Long
story short, they had no intention of adding the bigger collector.
Re: 408 broken in, now I need help to pick headers, [Re: S/ST 3040] #205600
01/27/09 10:12 AM
01/27/09 10:12 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
ive got a similar setup to yours. 416 ebody, auto, 4.30's 245/250, 565/576 lift on a 108 installed at 105. I got the hooker super comps. fit is great. not too low. no mods required. can change the starter without removing the header. can remove the headers without jacking the motor up (need to take the rt angle oil filter adapter off)
ive run 8.01 in the 1/8th so far but theres more in it. my 60' time sucks at 1.83 but my suspension is setup to cornering and not drag.
I would have liked the tti 1 3/4" but they didnt work with the TA fast ratio box.
One important note. My TA heads are ported. the port size on the head was LARGER than the header port on the hookers. and thats weird cause Im replacing an ancient set of hooker super comps from the 80's and those ports were a great match to my heads. The tti ports look even smaller than the hookers.
Re: 408 broken in, now I need help to pick headers, [Re: aarcuda] #205601
01/27/09 11:24 AM
01/27/09 11:24 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I would seriously consider the Dougs because they fit like the TTIs but don't cost as much and they are made just as well too. I love my TTIs except for the fact that the end tubes hang into the ports some on the lower outside corners. Pretty lame for a header that costs that much.
Re: 408 broken in, now I need help to pick headers, [Re: 71Pan] #205602
01/27/09 11:25 AM
01/27/09 11:25 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Any date when they will be released? I wonder if the end tubes will hang into the port like their step headers do?
Re: 408 broken in, now I need help to pick headers, [Re: 69Cuda340S] #205603
01/27/09 12:01 PM
01/27/09 12:01 PM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
I called tti they said early march. headers will only be offered coated.Hughes has two pair they say they look awesome (larger exhaust port window)
Now if we could only get edelbrock to make a victor sb head!!
Re: 408 broken in, now I need help to pick headers, [Re: 71Pan] #205604
01/27/09 12:23 PM
01/27/09 12:23 PM
NY usa
540challenger Offline
NY usa
Ya but once we get eddy to make a victor small block head then we will be complaining about no 2" tube headers lol
Re: 408 broken in, now I need help to pick headers, [Re: 540challenger] #205605
01/27/09 01:12 PM
01/27/09 01:12 PM
South Lyon, Michigan
6bblRoadrunner Offline
I run Hooker Super Comps (5204) in my 4spd Demon. These pipes are 1 3/4" and I have no problem with spark plug access. #1 tube bends straight down to go in between the K-frame, so their is no crossover tube blocking access to driver side plugs. These are designed for non-power steering. I did have to do some mods to one pipe to clear the pitman arm.
