Wheelbase question
#205100
01/26/09 07:24 PM
01/26/09 07:24 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What effects could result from having a wheelbase that is 1/2 longer on the drivers side than the passenger side? Would the wheelbase being off make it harder to hook consistently? Long story, but I knew my wheelbase was off. Took a measurement and it is about 1/2 longer on the pass side. If it matters, mono springs with cal tracs. The car drives fine on the road and at speed, but is finicky on hook.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Wheelbase question
[Re: Von]
#205101
01/26/09 07:26 PM
01/26/09 07:26 PM
Triple Threat
Renton Washington
It depends on why the wheelbase is longer? Lots of drag cars have some stagger built into the front ends. If the rear end was that crooked, which it doesn't sound like it is the car probably wouldn't drive very well.
[Re: Triple Threat]
#205102
01/26/09 07:39 PM
01/26/09 07:39 PM
Von
NE Oklahoma
The rear is that crooked. It is crooked because when I bought the car in 89 it had been wrecked. The drivers side front spring hanger was almost ripped off of the car. We put another hanger in the car, even though it was put back in pretty close to the same spot, it 3/8 to 1/2 inch off.
[Re: Von]
#205103
01/26/09 08:14 PM
01/26/09 08:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you had it 4 wheel aligned, if the rear IS off put a 1/2" spacer in front of the driver side hanger to square it up. With a 1/2" off on the axle it will try to drive you crooked and your always correcting or scuffing. When I align mine the rear is a MAX of 1/16" out
[Re: MR_P_BODY]
#205104
01/26/09 08:23 PM
01/26/09 08:23 PM
Von
NE Oklahoma
Mr. P,
My plan was to get a piece of 1/2 plate, get a very good measurement, mill the plate to the exact measurement I need, then put in place to correct.
Would being out a 1/2 inch cost any ET?
[Re: Von]
#205105
01/26/09 08:30 PM
01/26/09 08:30 PM
MR_P_BODY
Mr. P, My plan was to get a piece of 1/2 plate, get a very good measurement, mill the plate to the exact measurement I need, then put in place to correct. Would being out a 1/2 inch cost any ET?
If it is truely the rearend is crooked then yes it will make some difference... maybe a hundredth but how knows. Square it off of something thats ahead of the crashed part, use the oblong holes in the frame rails, they were jigging hole
