Adaptor plate #205012
01/26/09 05:42 PM
01/26/09 05:42 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Anyone got a part# for the adaptor plate between indy manold & carb? want to bring the dominator up level , the 4150 manifolds have the wedge built into them so the carb sits level.
Re: Adaptor plate [Re: 602heavy] #205013
01/27/09 05:48 PM
01/27/09 05:48 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Ok found the wedge plate.
Do most of you guys run the dominator with a tilt rearwards? or do you fit the wedge plate which brings it up 5/10*?
I realise the carb has to sit back a few degrees on a track motor , but if the front lifts on the launch would it not be better to level the carb.
