Re: Carter AVS or Holley?
[Re: ChuckinNY]
#2048364
04/06/16 10:21 PM
04/06/16 10:21 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Art,thanks for the info and the link for the rebuild kits. On a side note,how do you like those Alfas? I was looking at a local Alfa Spider Veloce for sale..looks like a nice clean car that needs a little TLC! Something different from the Mopars,but I,m open to anything on wheels that is fun to drive. I do love them. Yes for sure Alfa's are super fun to drive, manual shift and to get the power out you rev high, so the experience is just great. Handling and balance are excellent. Parts and advice are plentiful (surf around, look in their classifieds and even ask if anyone knows about your Spider on www.alfabb.com) and not expensive. Upgrades are also plentiful. They do take extra care though, like things have to be repaired before they fail.. - My '82 has the fantastic V6 and been very reliable. - The '94 has the bigger V6 with 24valves, but has electrical issues that are hard to really get completely sorted out. Modern stuff gets complicated. Bummer. But don't let a '94 sedan scare you away from a nice used Spider! They would be a great start, Good luck! - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: ChuckinNY]
#2049067
04/07/16 06:35 PM
04/07/16 06:35 PM
Posts: 14 New York
ChuckinNY
New York
Thanks for all the help and advice! I have a feeling that I should be good with either carb. I think what I,ll do is,when its ready to fire up,I,ll put the Carter back on and use that until the car is up and running and all the bugs are worked out. Then as time permits,I,ll try the Holley and see if there is much of a change. I,m not looking for the last 10th of a second or anything like that,but since I have the Holley and probably will keep it,I might as well monkey around with it. Back in the day when I was constantly buying and selling Cudas and Roadrunners and all the other Mopars,it was just normal to pull the original carb and put a Holley on. The GTX is the only one I can recall that I kept the original carb on! It has served me well.
[Re: Paul_Fancsali]
#2049578
04/08/16 11:36 AM
04/08/16 11:36 AM
Posts: 792 Earth
Rob C
Earth
Other then the carters loving to cut out in sharp bends unless you really work them a carter AVS is fine . If such is the case, your float levelis low. Raise it up and it won't cut out. I vote AVS. OE 750 or Edel. 800.
[Re: Runner]
#2049851
04/08/16 05:06 PM
04/08/16 05:06 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
i think either carb is fine, but im always surprised at how much flack holleys get for leaking. i have holleys on all my junk and none of them leak. they all run good and are trouble free. now, i have worked on some that had issues when no fuel filter was used and there was a bunch of junk in the tank Same here. I have had the same 750 Holley DP on my sons Dart since 1997 and it has never leaked and works flawless. The 850 on my 63 has been on it since 2006 and is the same with never a leak and works great. Carters and Eddy carbs are good too as I have no problem using either. I just like Holley's better on my muscle cars. Ron
[Re: Rob C]
#2050093
04/09/16 12:18 AM
04/09/16 12:18 AM
Posts: 279 pgh pa
captaindodge
pgh pa
Other then the carters loving to cut out in sharp bends unless you really work them a carter AVS is fine . If such is the case, your float levelis low. Raise it up and it won't cut out. I vote AVS. OE 750 or Edel. 800. Trouble is when you raise up the float level it will cut out under hard braking!
