4.500 bore mega block pistons #205007
01/26/09 05:36 PM
01/26/09 05:36 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
I am using a 4.500 stroke x 4.500 bore with 572-13 indy heads and i need pistons.
I am using a 6.950 GRP rods and want to zero deck the block.I am not going to o-ring the heads so i will be taking enough off the block to get rid of the receiver grooves.
My main question is does anyone know of a set of off the shelve pistons that will work in this motor since i can deck the block down to the piston height.
Trying to stay away from custom pistons if possible.
Thanks in advance
Re: 4.500 bore mega block pistons [Re: sc301v] #205008
01/26/09 05:53 PM
01/26/09 05:53 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You need a piston compression height near 1.55-1.56 range..I wouldnt deck the crap out of that block, to make odd ball pistons work. It will come back and bite you later
Re: 4.500 bore mega block pistons [Re: sc301v] #205009
01/26/09 06:15 PM
01/26/09 06:15 PM
there are shelf pistons but that doesn't mean they'll work for your application. i'm doing a couple sets of customs right now. one of them is for the same exact rod length and bore size. if you want more info let me know. i'll be happy to share what i know.
Re: 4.500 bore mega block pistons #205010
01/26/09 06:21 PM
01/26/09 06:21 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Thanks guys...If i have to go with customs that will be fine also i was just trying to get away with not waiting a couple months on them to be made.
DRAM you have a P.M.
Re: 4.500 bore mega block pistons [Re: sc301v] #205011
01/27/09 12:36 AM
01/27/09 12:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Do the valve angles of the 572-13 make a shelf piston even possible? One more tidbit from the peanut gallery, might want to check rod to cam clearance with the GRP's
