Re: My bracket hemi build
[Re: Polarapete]
#2048238
04/06/16 07:45 PM
04/06/16 07:45 PM
Triple Threat
Renton Washington
Should fire up in the next couple days. Might visit the track this weekend if all goes smoothly.
[Re: Triple Threat]
#2048646
04/07/16 09:07 AM
04/07/16 09:07 AM
Posts: 369 Indy
496 A-body
Indy
Should fire up in the next couple days. Might visit the track this weekend if all goes smoothly. What water pump is that?
[Re: Triple Threat]
#2048823
04/07/16 01:52 PM
04/07/16 01:52 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
a tad more expensive than my $80 ebay BBC pump. Don't tell the Chinese police
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Triple Threat]
#2048906
04/07/16 03:48 PM
04/07/16 03:48 PM
Triple Threat
Renton Washington
I didn't like the BBC option because the lower hose is on the wrong side, I would have needed a new radiator to go along with it. I've also had bad luck with water pumps and motor plates leaking, so this seemed like a good alternative.
$400 water pump and $300 worth of -16 fittings and lines.
As the kids like to say YOLO.
[Re: Triple Threat]
#2049358
04/08/16 12:07 AM
04/08/16 12:07 AM
sixpackgut
Charleston
If you buy the chinese ebay junk, i got a water pump with lower hose out for either side
[Re: Triple Threat]
#2049648
04/08/16 01:06 PM
04/08/16 01:06 PM
Triple Threat
Renton Washington
Now ya tell me.
It started last night.... Might get some video later today. There's a few hiccups to deal with first.
[Re: Triple Threat]
#2049668
04/08/16 01:25 PM
04/08/16 01:25 PM
sixpackgut
Charleston
Now ya tell me.
It started last night.... Might get some video later today. There's a few hiccups to deal with first. right on. oil pressure?
[Re: Triple Threat]
#2049672
04/08/16 01:36 PM
04/08/16 01:36 PM
Triple Threat
Renton Washington
Lots, it has straight 30 weight break in oil in it.
Gonna need some thin oil once its squared away.
[Re: Triple Threat]
#2049893
04/08/16 06:10 PM
04/08/16 06:10 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Glad to hear its running.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Triple Threat]
#2051160
04/10/16 05:15 PM
04/10/16 05:15 PM
sixpackgut
Charleston
Dustin has put its first 2 passes on his little hemi
[Re: sixpackgut]
#2051192
04/10/16 06:08 PM
04/10/16 06:08 PM
Posts: 369 Indy
496 A-body
Indy
Dustin has put its first 2 passes on his little hemi Sweet! How did it do?
[Re: 496 A-body]
#2051240
04/10/16 07:16 PM
04/10/16 07:16 PM
sixpackgut
Charleston
Dustin has put its first 2 passes on his little hemi Sweet! How did it do? Guy in a wheelchair beat him to the 60
[Re: sixpackgut]
#2051760
04/11/16 12:32 PM
04/11/16 12:32 PM
Triple Threat
Renton Washington
Dustin has put its first 2 passes on his little hemi Sweet! How did it do? Guy in a wheelchair beat him to the 60 Haha, close to accurate! Ended up making 6 runs yesterday with the best being 10.28@131, 1.44 60 foot. Not bad for a 3500# ride. Typical me I was in a bracket race so I didn't make any changes to the timing or carb, will have to start playing with it at the next available test session. Good first outing, more to come!
[Re: sixpackgut]
#2051765
04/11/16 12:35 PM
04/11/16 12:35 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Shhhhhh. I heard but I'm not telling. Nice runs!!!!!!!!!!
[Re: pittsburghracer]
#2051972
04/11/16 05:08 PM
04/11/16 05:08 PM
sixpackgut
Charleston
Dustin, what was the other combo? in the first thread you said it was a 450. what heads were on that? I guess the converter doesn't stall 5800 behind this engine either
[Re: Triple Threat]
#2052003
04/11/16 06:01 PM
04/11/16 06:01 PM
Triple Threat
Renton Washington
454" 4.185x4.125", Small block, B1-MC's, E85, 12:1, .619/.641 274/280@.050 "street" roller. It was a good combo til it broke a rod and cracked the main web in my R3. Lack of block availability turned me off from building it again.
Not sure about converter flash with the new combo yet, probably not 5800. I might go test Friday to answer some questions about jetting, timing, shift points etc.
