Re: Need help identifying my hemi origins
[Re: Hemi Steve]
#2046497
04/04/16 07:08 PM
04/04/16 07:08 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
528 prior to the World block , more than likely a Cummins Recon , if it is be VERY AFRAID ...
[Re: Hemi Steve]
#2046824
04/05/16 01:49 AM
04/05/16 01:49 AM
Posts: 4,848 Memphis
HemiRick
Memphis
The 1st 500 or so 528's were built by Arrow. Then Cummins took over. The Cummins engines had many problems. Many if not most were so bad they to had to fixed immediately, to be used. So yes your engine is probably a Megablock from the sound of it and I'm sure it has been fixed if it's now running well.
Yes world blocks have the freeze plugs on the front and an oil pump passage on the front.
My Cummins built 528 has pad stampings similar to yours.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Hemi Steve]
#2047048
04/05/16 01:04 PM
04/05/16 01:04 PM
JohnRR
U.S.S.A.
Also, is it fair to say that independent engine builders built 528's before the World blocks were available?
Steve
Not if it is a Mopar crate motor . My Cummins Recon 426 was a MESS , every machined surface had to be touched, the only original parts on the heads are the head castings, all new parts including guide liners was needed. The fact that someone was in that one is a good thing, but they needed to check everything.
[Re: Hemi Steve]
#2047304
04/05/16 07:13 PM
04/05/16 07:13 PM
JohnRR
U.S.S.A.
I knew I was going to have to go in it, but not to the extent that I did.
[Re: Hemi Steve]
#2047319
04/05/16 07:33 PM
04/05/16 07:33 PM
Posts: 528 SW CO
HemiSportFury
SW CO
My 528 was built by Indy Cylinder Head in 2000. It has the MP siamese block but Indy heads and intake.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: Hemi Steve]
#2047388
04/05/16 09:11 PM
04/05/16 09:11 PM
Posts: 528 SW CO
HemiSportFury
SW CO
I never heard that Indy built MP crate motors, but I could be wrong on that. They were not building them in 2000 when I bought mine, anyway.
[Re: Hemi Steve]
#2047770
04/06/16 11:11 AM
04/06/16 11:11 AM
JohnRR
U.S.S.A.
HemiSportFury: Did Indy build engines that were sold by Mopar Performance? If so what years? Somewhere in the back of my brain I thought I read that they did but I must admit when it comes to these engines its hard to keep track of who built which engine and when did they do it.
Steve No Indy did not build for MP. MP went with the LOWEST BIDDER and they got LOWEST BIDDER quality ...
[Re: Hemi Steve]
#2047989
04/06/16 02:54 PM
04/06/16 02:54 PM
HemiRick
Memphis
My 528 was rebuilt by Ray Barton under Mopars warranty. They paid him like $5000.
The markings on my pad are very similiar to yours large upright 528 with a smaller number upside down below it, my number is 02137 xxx. So I dont think your date code theory holds.
[Re: Hemi Steve]
#2048493
04/07/16 12:15 AM
04/07/16 12:15 AM
HemiRick
Memphis
HemiRick
OK, your number format is basically the same as mine so it looks like mine is a Cummins built engine. When did you get your engine? 2000 Did you get it straight from Mopar Performance? Yes, well kinda Koller Dodge Did you have problems immediately or did you do a "defensive" tear down? read this web page http://www.midsouthmopars.com/members/Rick/hemi.htm What intake and carbs do you have? Running EFI a single 1000 CFM throttle body on M1 intake Did you keep the original cam or did Barton make improvements along with the rebuild...Dyno results?? Mopar would not pay Barton if we used a diff cam. I since replaced it with a solid roller. [/quote]
