Re: Survivor R6 1969 Charger Garage find-383/727
[Re: 70B5Cuda]
#2056356
04/17/16 08:24 PM
04/17/16 08:24 PM
Posts: 1,064 Newton, KS
70B5Cuda
Newton, KS
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: basketcase]
#2058153
04/20/16 02:24 AM
04/20/16 02:24 AM
Posts: 422 wisconsin united states
keith airgrabber
Right in the Nutz!!!
oh that's just a column shift car..not worth bothering with ..I'll be right over and take that off your hands..... and what lotto numbers do you play? sweet find! and don't let the four wheel drums scare you. I've been driving Chargers and road runners with 4 drums since '83, and never had a problem. just R&R, keep adjusted properly and they work fine. 4 drums stop plenty fine.What an awesome car. Very nice
[Re: 70B5Cuda]
#2060885
04/24/16 04:28 PM
04/24/16 04:28 PM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2078820
05/23/16 02:01 PM
05/23/16 02:01 PM
70B5Cuda
Newton, KS
I replaced the master cylinderr and all 4 wheel cylinders. My buddy Mark (GY3 here on moparts) was nice enough to rebuild the carburetor for me. He found that it was clean with new gaskets (30 years old but never used) and that the two needles had different diameters and were reversed so the plungers were bound up and didn't work at all. Mark is guessing that the carb was rebuilt and wouldn't run so that's why it was parked! Swapping those different diameter needles may have been the reason for the car being so well preserved!! I started the car up and it ran nicely but it ran hot so I pulled the radiator and took it to a local shop. The radiator was plugged and had multiple leaks so I had it recored by a local radiator shop. Good radiator sops are getting hard to find, but this was a father and son that are pretty old school. The only thing I didn't like was that they use a glossy black radiator paint so I told them just to leave it unpainted. I ordered some satin radiator paint from Eastwood's and sprayed it yesterday in the back yard. I replaced the water pump and thermostat while I was at it.
[Re: 70B5Cuda]
#2118309
07/26/16 05:34 PM
07/26/16 05:34 PM
70B5Cuda
Newton, KS
It's been awhile since I've updated this thread. Replacing the alternator was the last mechanical fix I've made. I had a local guy polish the original paint for me, clean/treat the vinyl top, and clean the interior. Here are a couple early pics to show the contrast. Some better finished pics coming in a few minutes.
[Re: 70B5Cuda]
#2118311
07/26/16 05:40 PM
07/26/16 05:40 PM
70B5Cuda
Newton, KS
[Re: rocksmopar]
#2119273
07/27/16 07:37 PM
07/27/16 07:37 PM
Posts: 4,664 Wichita
GY3
Wichita
It's like you walked onto a used car lot in ~'72 and bought this car. It's that clean!
