Re: Your low ET's 11's 10's with 3.23/3.55 gear
[Re: ademon]
#2406148
11/20/17 12:08 AM
11/20/17 12:08 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Been 9s with 3.55s with a 493 and g3 hemi
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: ProSport]
#2406620
11/21/17 01:10 AM
11/21/17 01:10 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
This thread made me decide to go with 3.23 gears in my Duster awhile back, I finally got to drive it to the track this year and it went 10.69 at 124.75 with a 1.51 60 foot. I'm extremely happy with it. 500" low deck, 10to1 compression, small 557 lift purpleshaft cam, Eddy cnc ported MW heads, 950 carb, small B-body 1.75" headers, mechanical water pump and fan, never runs hot. 727 with Dynamic 9.5" converter that needs tightened(17.5% slip), 8.75 rearend with factory leaf springs with one new leaf added to each spring, Rancho adjustable rear shocks, 275/60 drag radial. Launch at 2000, shift at 5800, trap at 5800. I really like my 9.5 Dynamic converter I run. How tall are the rear tires you run with the 3.23's at the track Bob ? Ron
[Re: ademon]
#2406684
11/21/17 09:04 AM
11/21/17 09:04 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
28" tall, 275/60 drag radial.
[Re: sixpackgut]
#2407309
11/22/17 12:19 PM
11/22/17 12:19 PM
ProSport
Akron, Ohio
Been 9s with 3.55s with a 493 and g3 hemi That is an impressive combo
[Re: ademon]
#2509082
06/15/18 08:18 PM
06/15/18 08:18 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
1st pass since freshen up, 11.33 @ 121 ,1750 DA, have not done any tuning yet, probably wont be able to car has no roll bar, it is my daily driver. 1968 Dodge Charger,4100lb with me Street car, COLD AC, 512 low deck, 440 source stroker kit 9.7 compression, Hughes hydro roller cam 255,258@.050, .608/.613 lift with 1.6 T&D rockers with B3 geometry correction, Indy 400-2 intake that I ported to max wedge,1050AN 4150 pieced together carb, 440 source Super stealth heads max wedge size that I ported flow 330 @ .700, with Farrea valves, Comp Beehive springs, 1 7/8 headers, full 3" magnaflow exhaust & tail pipes. A518 overdrive trans,4000stall lock up converter, alum driveshaft, 3.54 Strange Dana 60, Caltrac bars & split mono springs with sliders. 325-50-15 MT drag radials street. drove 80 mph, 80 mile round trip to the track, dropped the air pressure in the rear tires, turned of the AC & made a easy , short shifted pass, next pass went up against the converter 2500 & it blew the tires off, got to hot outside for me, drove home in the ac. I WAS ASLEEP [video:youtube] https://youtu.be/qusZAXyw9yc[/video] 2nd pass [video:youtube] https://youtu.be/UCgH0_V0dQY[/video]
[Re: GY3]
#2902160
03/23/21 07:15 PM
03/23/21 07:15 PM
Posts: 4,663 Wichita
GY3
Wichita
I posted this elewhere, but we got a new best of 10.69 @ 128 with 150 shot last Saturday. DA was well over 4000 ft. and it was at least 85°! May put the 200 jets in for tomorrow night... or I guess this was a while back! We went 10.01 @ 133 last Fall.
[Re: GY3]
#2902307
03/24/21 10:31 AM
03/24/21 10:31 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I've been 8.97 at 152.5 mph w/ 3.54 gears at 3900 lbs. I've been a good bit quicker since then, but I've only been going to 1/8 mile tracks. Hopefully get a new 1/4 mile timeslip real soon.
[Re: an8sec70cuda]
#2902388
03/24/21 02:03 PM
03/24/21 02:03 PM
Posts: 188 MD.
vttm
MD.
I've been 8.97 at 152.5 mph w/ 3.54 gears at 3900 lbs. I've been a good bit quicker since then, but I've only been going to 1/8 mile tracks. Hopefully get a new 1/4 mile timeslip real soon. What size tire you running Chip?
[Re: vttm]
#2902393
03/24/21 02:15 PM
03/24/21 02:15 PM
an8sec70cuda
I've been 8.97 at 152.5 mph w/ 3.54 gears at 3900 lbs. I've been a good bit quicker since then, but I've only been going to 1/8 mile tracks. Hopefully get a new 1/4 mile timeslip real soon. What size tire you running Chip? 295-65 drag radial...about 30" tall.
