Re: Your low ET's 11's 10's with 3.23/3.55 gear
[Re: ademon]
#2052382
04/12/16 12:10 AM
04/12/16 12:10 AM
Posts: 344 Burlington, Ontario Canada
Dave_S
8.93@149 3.23 geared 8 3/4 5.7 Hemi 88mm turbo
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: BSB67]
#2053112
04/12/16 10:05 PM
04/12/16 10:05 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Car in sig is kinda close. Not low 11's, but mph suggests it has potential. I think it is reasonable to think my car with a 2400 rpm converter, headers, and a 200 lb. car diet would put it in the low 11's.
The car's 60 ft is 1.90 sec, and the converter won't stall past 1800/1900 rpm. you dont need headers or a diet........put a converter in it low 11s no prob with 120mph.i bet it would be in the 10s with all the above.what cam u running? Thanks. You are probably correct, I just didn't want to sound too presumptuous. I agree as you have the power for 11.0's at 120 mph. Conveter and some chassis tuning and you could be in the very low 11's. Ron
[Re: ademon]
#2237186
01/19/17 11:32 AM
01/19/17 11:32 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I just found this thread, and it gives me hope! Thinking about taking my Duster to the track this year with 3.23 gears, 28" drag radial, and 9.5" converter.
Do any of you know your trap rpm?
[Re: GY3]
#2237191
01/19/17 11:44 AM
01/19/17 11:44 AM
Posts: 4,663 Wichita
GY3
Wichita
S A little update. My car ran an 11.30 @ 119.8mph this weekend.
The mph says I have an 11.0 waiting on me if it ever hooks well!
Whittled down to an 11.1 @ 121 mph end of last season. Trying to resolve rear suspension issues.
[Re: ademon]
#2237243
01/19/17 02:01 PM
01/19/17 02:01 PM
ProSport
Akron, Ohio
2.94's would be sweet on the highway. I don't care for my 3.23's on the highway but most guys wouldn't mind it at all. I had 3.55's and hated them but they'd be better on the strip.
Go for the better Heads so you have room to grow. My motor is a pump gas 500" with CNC max wedge Edelbrock's. It has a small cam and small headers, seems to have alot of torque so I'm hoping to hit high 10s or low 11s driving to and from the track.
[Re: OUTLAWD]
#2237330
01/19/17 05:03 PM
01/19/17 05:03 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Not low 11's but 11.50 @ 116 66 Belv. 493, -516 iron heads, .530 cam, 9.5" converter, 3.55's and a 28" tall tire. I have a plate on it but have yet to open the bottle up. The converter is probably a bit loose, but I expect high 10's with a relatively small shot.
I ended up hitting the Belvedere with a 0.051 N2O jet. It ran a string of 10.95-10.98 once I got the timing where I wanted it, before I got a talking to for no roll bar It had a 10.8x in it, but the track was going away and they shut it down before I could get the launch sorted Car is 3700# at the line. I basically use it as a daily driver during the 2 month MI summer...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: ademon]
#2237345
01/19/17 05:44 PM
01/19/17 05:44 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have been 9.70 with my 493 at 3300 lbs with 3.55 gears, this combo would have went 9.50s but decided to change directions without ever getting the slip I have been 9.88 with 426 g3 at 3240 lbs with 3.55 gears
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2237394
01/19/17 06:55 PM
01/19/17 06:55 PM
ProSport
Akron, Ohio
I have been 9.70 with my 493 at 3300 lbs with 3.55 gears, this combo would have went 9.50s but decided to change directions without ever getting the slip I have been 9.88 with 426 g3 at 3240 lbs with 3.55 gears Very impressive Ray. What RPM do you trap at? 275/60/15?
[Re: ProSport]
#2237515
01/19/17 09:28 PM
01/19/17 09:28 PM
sixpackgut
Charleston
I have been 9.70 with my 493 at 3300 lbs with 3.55 gears, this combo would have went 9.50s but decided to change directions without ever getting the slip I have been 9.88 with 426 g3 at 3240 lbs with 3.55 gears Very impressive Ray. What RPM do you trap at? 275/60/15? Im thinking both combos are under 6800. Ive have either 325/50 or 295/55 on my car
[Re: OUTLAWD]
#2237520
01/19/17 09:37 PM
01/19/17 09:37 PM
GY3
Wichita
I ended up hitting the Belvedere with a 0.051 N2O jet. It ran a string of 10.95-10.98 once I got the timing where I wanted it, before I got a talking to for no roll bar It had a 10.8x in it, but the track was going away and they shut it down before I could get the launch sorted Car is 3700# at the line. I basically use it as a daily driver during the 2 month MI summer... Awesome! I thought about doing this for the upcoming season as well. What did you set your total timing at? Did you change spark plugs to a different heat range?
[Re: sixpackgut]
#2237584
01/19/17 11:40 PM
01/19/17 11:40 PM
ProSport
Akron, Ohio
I have been 9.70 with my 493 at 3300 lbs with 3.55 gears, this combo would have went 9.50s but decided to change directions without ever getting the slip I have been 9.88 with 426 g3 at 3240 lbs with 3.55 gears Very impressive Ray. What RPM do you trap at? 275/60/15? Im thinking both combos are under 6800. Ive have either 325/50 or 295/55 on my car With a 28" tire, 3.55's, and a mph of 136 I'm getting only 6000 RPM's, which sounds about right to me. Are you running naturally aspirated?
[Re: SILVER67]
#2237631
01/20/17 12:29 AM
01/20/17 12:29 AM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have been 10.91 with 3.54 gears but my 5-speed has a 3.37 low gear so that makes for a nice mechanical advantage. I will be interested to see how the car reacts with a 4.10 gear and a 2.66 low gear in a stock HEMI box. Last time out I was driving through the clutch which was indicated by the 126 MPH. with an 11.09 ET. Someday I will get my clutch tuned but I don't spend enough time at the track to get it dialed in on kill. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: challengermike]
#2237648
01/20/17 12:49 AM
01/20/17 12:49 AM
383man
Balt. Md
Last year I blew the 4.30s I had in my car and put 3.23s I had laying around and my 60ft was still the same 1.50 and the et was still the same, usually 6.9 to 7.2s. That's in an 72 dart with a 499 with a 3,200 stall. I did put shorter tires on 275/50 15 in place of the 295/65 15s. I was shocked to find out it ran exactly the same. It seems with the torque alot of the strokers have they run fast with not as much gear. And the shorter tires is like putting a high number gear in so that may have also helped keep the et about the same. Ron
[Re: ProSport]
#2237732
01/20/17 03:40 AM
01/20/17 03:40 AM
sixpackgut
Charleston
I have been 9.70 with my 493 at 3300 lbs with 3.55 gears, this combo would have went 9.50s but decided to change directions without ever getting the slip I have been 9.88 with 426 g3 at 3240 lbs with 3.55 gears Very impressive Ray. What RPM do you trap at? 275/60/15? Im thinking both combos are under 6800. Ive have either 325/50 or 295/55 on my car With a 28" tire, 3.55's, and a mph of 136 I'm getting only 6000 RPM's, which sounds about right to me. Are you running naturally aspirated? NA. My 493 was 140mph. The 426 135
