A-body manual gearbox on ebody? #204466
01/25/09 08:27 PM
01/25/09 08:27 PM
KY
juicedcuda Offline OP
KY
I have a 70 duster with a manual steering box. I would like to put it on my 70 Cuda but wasn't sure if it work, as far as mounting locations, length and steering arm?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: A-body manual gearbox on ebody? [Re: juicedcuda] #204467
01/25/09 09:38 PM
01/25/09 09:38 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
i would say that manual steering boxes are the same (except for ratios), no matter which body they are in. the pitman arms are probably different
i used a steering box from a '69 Coronet in a Dart, but did change the pitman arm
Re: A-body manual gearbox on ebody? [Re: juicedcuda] #204468
01/25/09 10:07 PM
01/25/09 10:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mopar made the external dimesions the same on all the early sterring boxes so they would fit all of the bodys style made then. Your boxes will interchange but yoy may need to change the pitman arms as already mentioned. The steering shaft in the ciolum will need to be lengthen also as the power steering box is longer than the manual box on the part the shaft hooks up to Be careful when you remove the power steering box, that rascal is not light at all
