Re: ?Carbs for a cross ram max wedge
[Re: Smoparmike]
#2047512
04/05/16 11:23 PM
04/05/16 11:23 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I run a heavily ported Victor 383 w/an adapter that`s blended nicely into the manifold and a Thumperized HP-1050.............
[Re: AndyF]
#2048156
04/06/16 05:51 PM
04/06/16 05:51 PM
Posts: 1,442 central ohio
nss guy
central ohio
I agree with you! I have more experence with holleys but none with dual carbs. I have a little time yet to decide for sure. If I was smart I would put a single Dommy on it. A single plane intake with a Dominator will make 100 hp more than a MW cross ram on a race type engine. When you think about it that means that the cross ram intake is destroying 100 hp of potential power but keeping the air and fuel from getting into the cylinders at the right time. I know that people love the look of the cross ram but sheesh, 100 hp is nothing to sneeze at. Plus the single 4bbl setup costs less and weighs less. How much ET are we talking about the 100hp loss with the factory crossram? I can run 10.20's thru the mufflers with these small air cleaners on. Curious how quick I could go with a single plane and dominator.
[Re: Smoparmike]
#2048336
04/06/16 09:40 PM
04/06/16 09:40 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
9:70's in 3300 lb. in. Nss car stock xram 750 edies.
JAKES AUTOMOTIVE
[Re: Smoparmike]
#2048700
04/07/16 10:40 AM
04/07/16 10:40 AM
Posts: 428 wappinger falls new york
Jimi_Vignogna
I knew the cross ram would cost me big power. I have the cross ram, linkage and bolts already so I will use it. I would like to try a single setup just to see the difference. What intake would you suggest? It is a 440 base 505 with ez heads by porter racing and a solid roller cam 264/270 dur @50 110 lobe sep and .631 lift. Thanks Mike duration is wrong for a cross ram engine that will work with a short runner single plain intake. cross ram should be the other way around. 270 intake 266 exhaust
[Re: AndyF]
#2048702
04/07/16 10:43 AM
04/07/16 10:43 AM
Jimi_Vignogna
I agree with you! I have more experence with holleys but none with dual carbs. I have a little time yet to decide for sure. If I was smart I would put a single Dommy on it. A single plane intake with a Dominator will make 100 hp more than a MW cross ram on a race type engine. When you think about it that means that the cross ram intake is destroying 100 hp of potential power but keeping the air and fuel from getting into the cylinders at the right time. I know that people love the look of the cross ram but sheesh, 100 hp is nothing to sneeze at. Plus the single 4bbl setup costs less and weighs less. not disagreeing with you but the most we have ever seen on a dyno (stock eliminator engines) going from a cross ram to a single 4 is 45 hp that with changing cam shaft.
[Re: Jimi_Vignogna]
#2048935
04/07/16 04:27 PM
04/07/16 04:27 PM
Posts: 30,989 Oregon
AndyF
I agree with you! I have more experence with holleys but none with dual carbs. I have a little time yet to decide for sure. If I was smart I would put a single Dommy on it. A single plane intake with a Dominator will make 100 hp more than a MW cross ram on a race type engine. When you think about it that means that the cross ram intake is destroying 100 hp of potential power but keeping the air and fuel from getting into the cylinders at the right time. I know that people love the look of the cross ram but sheesh, 100 hp is nothing to sneeze at. Plus the single 4bbl setup costs less and weighs less. not disagreeing with you but the most we have ever seen on a dyno (stock eliminator engines) going from a cross ram to a single 4 is 45 hp that with changing cam shaft. Sounds very reasonable for a stock eliminator engine. The engine where I saw 100 hp increase was 505 inches with Indy heads. The stock intake was very restrictive at 505 inches so the flow increase bigger when we switched to 4500 intake. The OP in this thread has a 505 inch engine so that is why I was using that number.
[Re: Smoparmike]
#2049365
04/08/16 12:13 AM
04/08/16 12:13 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'll just throw this out as an untested counterpoint to the 100hp loss from the factory x-ram. I dynoed a 12:1 RB499, ported Indy -1's, .650 lift roller, 2-2 1/8 headers, OE stage II manifold, FM carter 750's. It made 675hp like that. I didn't test any other manifolds on it, but I just don't think there was another 100hp to be had out of that motor by installing a 440-3 and a dominator. I suppose it might have made 775hp, but I know I've built "better" motors than that before that didn't get there.
