Re: ?Carbs for a cross ram max wedge
[Re: Smoparmike]
#2045618
04/03/16 07:03 PM
04/03/16 07:03 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
On the two stroker motors I dynoed that had Indy heads and a x-ram intake with edelbrock 750 carbs, when jetting for best power, I ended up with jetting quite a bit richer than the as delivered edelbrock jetting. One was 675hp, the other was 745hp.
One of those came to me with torched head gaskets from being run too lean.....and those carbs were richer than stock as well.
[Re: Smoparmike]
#2045677
04/03/16 09:07 PM
04/03/16 09:07 PM
fast68plymouth
So. Burlington, Vt.
Although the ede 750's and the last of the carter 750's were both made by weber, and both came with the same jets and rods, they did not provide the same a/f ratio when run on the same motor back to back. Subsequent disassembly and inspection showed definite differences in the calibration with the air bleeds and clusters.
No way would I assume that the jets for an OE MW carb would be optimum for an aftermarket similar version of that model carb just because the throttle bores and venturii are the same size. In the same way not all 750 Holleys are supplied with the same jets, or would require the same jets, to achieve equivalent a/f ratios on a given engine combo.
[Re: Smoparmike]
#2045944
04/04/16 01:41 AM
04/04/16 01:41 AM
fast68plymouth
So. Burlington, Vt.
116/113 jets is way richer than some on this thread are recommending, but that's in line with where I ended up with the ones I had on the dyno.
On a 557 with the Indy intake I was at 119 on all 8 holes with the performance series Carter 750 carbs. Again, I was jetting for power.
Honestly though, I'm all for people finding out what works best for them. The main point of my initial post on this thread was to just encourage jetting on the rich side "just in case". The ramifications of taking that approach is a little less costly that finding out you're way too lean.
[Re: Smoparmike]
#2046032
04/04/16 04:59 AM
04/04/16 04:59 AM
Posts: 117 Aus
hysteric
Aus
The Edelbrock 750 has 1 major problem and that is the length of the primary booster is shorter than it should be. Any early pre Carter/FM 750 will have the correct longer booster if you want to compare. From memory when i compared the both the longer booster activated the primary flow sooner. Heres an Eddie 1407 thread at Speedtalk: Edelbrock 1407I would look to the NSS guys for guidance as thats their bread and butter. Also heres a write up from Dan Dvorak on AFB's. Well worth the download price $1 for what he knows. Carburetion: A maximum performance treatise Hope this helps Hysteric
[Re: Smoparmike]
#2046168
04/04/16 12:26 PM
04/04/16 12:26 PM
fast68plymouth
So. Burlington, Vt.
Thanks for the link.....a lot of interesting info there. Answers some questions as to perhaps why some of those carbs just can't seem to be sorted out with normal tuning methods.
When I get a chance I'll read through the stuff from Dvorak.
[Re: hysteric]
#2046202
04/04/16 12:56 PM
04/04/16 12:56 PM
Posts: 145 NJ
cb1289
NJ
Great read! We need more posts like this on Carter/Eddy carbs.
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: fast68plymouth]
#2046205
04/04/16 12:57 PM
04/04/16 12:57 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
As far as the boosters go I know some Demon carbs have that issue like the King Demon I just converted to a 2-circuit for a 1000+ hp BB Chevy. The booster is too high in the venturi making the depression point less than desireable and a weaker signal needing more fuel when the boosters are active and making it richer down low..............
[Re: Smoparmike]
#2046806
04/05/16 01:19 AM
04/05/16 01:19 AM
Thumperdart
State of confusion
Are you stuck on AFB`s? Can you run Holleys?
[Re: Smoparmike]
#2047050
04/05/16 01:09 PM
04/05/16 01:09 PM
Thumperdart
State of confusion
I know some haul azz w/the AFB/E-brocs and agree they look more "correct" but I still love the easy tunability of the Holleys and they just look meaner to me...........
[Re: Thumperdart]
#2047083
04/05/16 01:49 PM
04/05/16 01:49 PM
Posts: 369 Bowler Wisconsin
Smoparmike
Bowler Wisconsin
I agree with you! I have more experence with holleys but none with dual carbs. I have a little time yet to decide for sure. If I was smart I would put a single Dommy on it.
[Re: Smoparmike]
#2047097
04/05/16 02:04 PM
04/05/16 02:04 PM
Thumperdart
State of confusion
I think w/properly calibrated duals, the distribution would be better but a Dommy gets it done everyday for many...........
[Re: Smoparmike]
#2047240
04/05/16 05:14 PM
04/05/16 05:14 PM
Posts: 30,992 Oregon
AndyF
I agree with you! I have more experence with holleys but none with dual carbs. I have a little time yet to decide for sure. If I was smart I would put a single Dommy on it. A single plane intake with a Dominator will make 100 hp more than a MW cross ram on a race type engine. When you think about it that means that the cross ram intake is destroying 100 hp of potential power but keeping the air and fuel from getting into the cylinders at the right time. I know that people love the look of the cross ram but sheesh, 100 hp is nothing to sneeze at. Plus the single 4bbl setup costs less and weighs less.
[Re: AndyF]
#2047265
04/05/16 06:12 PM
04/05/16 06:12 PM
Thumperdart
State of confusion
On a different note, a GOOD t-ram intake will make more power than a single in most applications.............NOT cross ram............
