Re: The "myth" of ram air.. does it WORK in cars/trucks?
[Re: DARTH V8Я]
#2042929
03/31/16 08:09 PM
03/31/16 08:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's not a matter of opinion if it works or not.
It's a matter of fact, it either works or it does not, no opinion involved.
[Re: DARTH V8Я]
#2042957
03/31/16 08:43 PM
03/31/16 08:43 PM
Posts: 22,695 Bitopia
jcc
Bitopia
My opinion, done right, there is no downside. Doing it right, is not always easy or obvious. I also suspect most reports of gains, are more from getting a cooler air inlet source, rather then any 'ram' effect.
[Re: DARTH V8Я]
#2043027
03/31/16 10:15 PM
03/31/16 10:15 PM
Posts: 5,993 Salem
Grizzly
Moparts Proctologist
Salem
Fiction.
You can "ram" as much air in there as you like, but it won't make fart in the wind difference: there's a thing called an air filter standing in the way.
Mo' Farts
Moderated by "tbagger".
[Re: 71birdJ68]
#2043173
03/31/16 11:53 PM
03/31/16 11:53 PM
RapidRobert
cold(er) air & I think there'd have to be some pressure increase. It'd have to have some bennie, maybe alot. No actual back to back testing done here tho
[Re: RSNOMO]
#2043213
04/01/16 12:20 AM
04/01/16 12:20 AM
Posts: 43,458 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Ram air works great! The problem is figuring out the correct carburetor mixture from idle to the speed where the ram air works the best without being too rich at idle to that point and when too much air will lean it out!
JB Rhinehart, Realist
A-Body's RULE!
[Re: DARTH V8Я]
#2043332
04/01/16 08:35 AM
04/01/16 08:35 AM
Supercuda
About to go away
About to go away
up yours
Problem with the examples given in this thread is that most, if not all, of the improvements are due to not using warm under hood air and are not due to ram air effect. NASA did some testing and it really isn't until you hit 100 mph that any noticeable effect is seen. Of course design (getting above the boundary layer)is important and I don't see any of the pictured scoops designed to do that. I suspect that the mixture issues mentioned are due more to turbulence of the airflow through the carb than a pressure increase in general, after all that is what makes a carb work.
For a street cars, it's for looks. A race car may see ram air effects at the top end of the run.
[Re: DaytonaTurbo]
#2043377
04/01/16 10:40 AM
04/01/16 10:40 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
Did a lot of work on this in the old Comp car. Figuring the area of the scoop inlet and where the tipping point was as far as at what speed the scoop was travelling vs the engines inlet demands. At that velocity and higher the engine sees a positive pressure in the scoop. Ram air as it were.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: 360view]
#2043408
04/01/16 12:05 PM
04/01/16 12:05 PM
jcc
Bitopia
"Some strange facts: At 70 mph the center of your tire is moving 70 mph. The bottom of your tire where it 'grabs' the pavement is moving at 0.1 mph The top of your tire is moving forward at 140 mph."
That point was made here in 2011 with an explanation of Weldon's Vegas Indy car fatality, nobody got it then either.
[Re: DaytonaTurbo]
#2043431
04/01/16 12:33 PM
04/01/16 12:33 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Cool air = better than hot air. In fact I'm surprised that after all these years of hotrodding, the standard open element 4 barrel air cleaner sucking in hot under hood air is still the gold standard. I have wondered about that too. When a gasoline engine is idling, Does it use less gallons in an hour With hot air? At idle Intake side pumping losses are high Because the throttle is nearly closed. Hot air has less oxygen per cubic foot than cold air, So the throttle has to open a bit more And idle vacuum has to drop, Therefore more atmospheric pressure is available To push the piston downward on the intake stroke. This reduces intake pumping loss. My 1995 Magnum 5.9 V8 seems to have a complicated fender side air inlet system that sucks hot engine compartment air at idle, but when the truck is moving gets cooler air from a passage in the fender that has its inlet up by the passenger side headlight. It is so complicated that it has to be designed that way on purpose. Since they are using the fender sheet metal as an air passage, Why didn't the designers get the engine air from a vent high up on the passenger side A pillar. This "snorkle" inlet would have other advantages.
