Re: The "myth" of ram air.. does it WORK in cars/trucks?
[Re: DARTH V8Я]
#2044504
04/02/16 03:38 PM
04/02/16 03:38 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Don't give up because some people offer up invalid assumptions and opinions - TRY IT FOR YOURSELF.
This is true of people. However the science of fluid dynamics doesn't lie. Great conversation though, interesting opinions there is a saying... "spare me your technical BS and show me your time slip" Science and theory is great, but i'll take real world track numbers anyday.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Supercuda]
#2044611
04/02/16 06:12 PM
04/02/16 06:12 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
A map sensor doesn't show flow turbulence though. turbulent air thru the carb is not optimal. I might need to make one. There are horsepower dividends to be found here. My builder uses those contoured plastic stub stacks on some of his hydroplane engines. Good for several HP (less than 10) on a 2.5 litre engine. The theory is they straighten out the airflow into the carb. If you race with no air filter, leaving the filter base on depending on how it's shaped is supposed to help for similar reasons. Not knowing the correct engineering speak but it's either aero or fluid dynamics (Maybe both?) at work I believe. Kevin
[Re: DARTH V8Я]
#2044713
04/02/16 09:07 PM
04/02/16 09:07 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
myth or not, atmospheric presser + 1 is boost, turbo, sc, or ram air.
Have a great day Iowan
"obsolete is neat"
[Re: DARTH V8Я]
#2046536
04/04/16 07:42 PM
04/04/16 07:42 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Air is incompressible at speeds below 230mph. And what the difference between an online forum and some guy writing it out on a chalkboard in the 1930's?
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2046553
04/04/16 08:04 PM
04/04/16 08:04 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Ice, explain this: I believe you will find a similar device on every NASCAR vehicle in competition, including those tracks where speeds seldom exceed 120 mph.
[Re: DARTH V8Я]
#2046592
04/04/16 08:47 PM
04/04/16 08:47 PM
DARTH V8Я
Its a TRAP!
underhood = lower pressure near the windshield = higher pressure
the higher pressure air just moves into the area of lower pressure.
Considering most NASCAR noses are completely blocked off from incoming air and no scoops allowed, drawing air from the cowl is the most convenient spot I would think. But I ain't no engineer lol.
[Re: DARTH V8Я]
#2046656
04/04/16 10:19 PM
04/04/16 10:19 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"But I ain't no engineer"
We agree. LOL
Spend some more time re reading Wiki:
"Compressible aerodynamics[edit] Main article: Compressible flow According to the theory of aerodynamics, a flow is considered to be compressible if its change in density with respect to pressure is non-zero along a streamline. This means that - unlike incompressible flow - changes in density must be considered. In general, this is the case where the Mach number in part or all of the flow exceeds 0.3. The Mach .3 value is rather arbitrary, but it is used because gas flows with a Mach number below that value demonstrate changes in density with respect to the change in pressure of less than 5%. Furthermore, that maximum 5% density change occurs at the stagnation point of an object immersed in the gas flow and the density changes around the rest of the object will be significantly lower. Transonic, supersonic, and hypersonic flows are all compressible."
The word "arbitrary" stands out above, and the "compressibility" expressed is in terms mainly of aircraft aerodynamics, engine nlet intakes are much more responsive/sensitive to very low pressure changes relating to the original question posed, "fact or fiction", not "worth it or Not"
[Re: jcc]
#2046665
04/04/16 10:30 PM
04/04/16 10:30 PM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
IIRC, some years back one of the car mags did extensive testing of cold-air induction systems. I do recall one thing they mentioned was boundary layer air and the need to raise most scoops higher above the hood line to realize a true gain. "Ram Air" is somewhat of a misnomer as related to automobiles and seems to really be confusing some folks who are trying to take it literally. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: RSNOMO]
#2046710
04/04/16 11:22 PM
04/04/16 11:22 PM
DARTH V8Я
Its a TRAP!
This has GOT to be a record-breaking troll thread... Troll thread? Then I suggest you hit the notify button and give a reason to the moderators. Thanks.
[Re: DARTH V8Я]
#2046719
04/04/16 11:32 PM
04/04/16 11:32 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
FACT or FICTION: Would be interested in hearing your guys opinions. The trolling began with this post. You are not interested in hearing our "opinions", you are interested in trying to prove a point and therefore making yourself appear knowledgeable. I don't think it worked.
[Re: Pacnorthcuda]
#2046724
04/04/16 11:38 PM
04/04/16 11:38 PM
DARTH V8Я
Its a TRAP!
FACT or FICTION: Would be interested in hearing your guys opinions. The trolling began with this post. You are not interested in hearing our "opinions", you are interested in trying to prove a point and therefore making yourself appear knowledgeable. I don't think it worked. I'm not trying to prove a point.It's called counter arguments. That why I said I'm interested in all opinions. Had my mind sorta made up.. but not really. But whatevs dude.
[Re: DARTH V8Я]
#2046921
04/05/16 09:51 AM
04/05/16 09:51 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Considering most NASCAR noses are completely blocked off from incoming air and no scoops allowed, drawing air from the cowl is the most convenient spot I would think. But I ain't no engineer lol. Chevrolet did that with the '63 impala Z-11 cars.
[Re: Spaceman Spiff]
#2046937
04/05/16 10:19 AM
04/05/16 10:19 AM
jcc
Bitopia
Considering most NASCAR noses are completely blocked off from incoming air and no scoops allowed, drawing air from the cowl is the most convenient spot I would think. But I ain't no engineer lol. Chevrolet did that with the '63 impala Z-11 cars. You really mean "Smokey"?
