removing/installing engine in a C body....any tricks? #204162
01/25/09 04:10 PM
01/25/09 04:10 PM
Virginia
rm23j8g Offline OP
rm23j8g  Offline OP
Virginia
I'm starting to think about rebuilding the 318 in my '70 Fury.
I've pulled plenty of B body engines, both from the top in the old days and, more recently, from the bottom, which works great and I prefer now.
Are there any special tricks as far as engine removal/installation are concerned on these....and, is it even possible to remove/install from underneath like a B/E body?
Re: removing/installing engine in a C body....any tricks? [Re: rm23j8g] #204163
01/25/09 04:17 PM
01/25/09 04:17 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
cant come out the bottom unless you remove the entire front clip since there is no removable k frame but only a front sub frame which includes the frame rails.
Re: removing/installing engine in a C body....any tricks? [Re: rm23j8g] #204164
01/25/09 04:20 PM
01/25/09 04:20 PM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
No special tricks that I know of, but needs to come out the top. Unless you really want to pull both fenders, the hood, front bumper, rad support, etc. and then drop the subframe, complete with all front suspension. Have pulled C-body subframes before, and fun it ain't.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: removing/installing engine in a C body....any tricks? [Re: 05dakota] #204165
01/25/09 04:22 PM
01/25/09 04:22 PM
Virginia
rm23j8g Offline OP
rm23j8g  Offline OP
Virginia
Okay....that's what it looked like to me, but wanted to be sure I wasn't missing something obvious. Is there room for the trans to come out attached to the engine?
Looks like it's gonna be the old hoist/oak tree route!
Re: removing/installing engine in a C body....any tricks? [Re: rm23j8g] #204166
01/25/09 04:24 PM
01/25/09 04:24 PM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
Plenty of room with small blocks.
Re: removing/installing engine in a C body....any tricks? [Re: 75DART440] #204167
01/25/09 05:32 PM
01/25/09 05:32 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I removed big blocks from C's and did not even have to remove the hood!
Slides in and out real nice with the rad core support out of the car which is a bolt on item unlike A/B/E cars.
Yes,it is easier to remove with tranny attached,IMHO.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
