shock adjustments and reaction times #203823
01/25/09 11:24 AM
01/25/09 11:24 AM
Mb Can
demonstrator Offline OP
Mb Can
how does shock adjustment on front and rear qa1 shocks affect reaction times
Re: shock adjustments and reaction times [Re: demonstrator] #203824
01/25/09 12:22 PM
01/25/09 12:22 PM
Santa Rosa,CA USA
67dodgeracer Offline
Santa Rosa,CA USA
I know stiffer settings on extension for the rear will quicken my cars reaction.I think it's because there is less 'motion' in the suspension,almost like a hardtail dragster.The car just seems to make that initial move quicker.On the front,I would think a loose extension setting would keep the tire low and in the beam longer,thus a worse reaction time.
Re: shock adjustments and reaction times [Re: demonstrator] #203825
01/25/09 12:33 PM
01/25/09 12:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Like 67 said... in most cases if you stiffen the
rear extension it will react quicker... the front
will change it but it depends on how the car transfers
now. If it transfers the weight good now and you loosen
the front end it might yank the front tires straight
up instead of traveling forward
