AAARgh! pilot bushing backed out of eagle crank! 408 sb #203632
01/25/09 02:19 AM
01/25/09 02:19 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
First I had trouble getting a pilot bushing from eagle- the stock bushing for a 360 didn't fit my 4" crank and the first tech I talked to at eagle said sorry, better call a machine shop! Then I found out that eagle makes a bushing with a bigger outside diameter to fit their crank. Why didn't the tech dept. know that?
After I got it and put it in I thought it should be harder to install than it was like maybe a light press fit or whatever? Fast foreward a month or so-I had just gotten some good progress on my new build, the brakes and suspension are getting sorted, and the motor was getting close, when I started to get a whirring and screaching when the clutch pedal was pressed. I didn't know what it was, but I figured either pilot or throwout. I did know I had to pull the trans.
The lakewood bell is a m/f to pull without taking the motor out but today I got it off with a little help from a buddy. It looks like the pilot bearing backed out of the crank and got stuck inbetween the crank and the clutch disc? one side of it was whittled and there was some debris in the crank pocket.
I think I might go with the late model roller bearing from a magnum truck or whatever I gotta tell the parts idiot at the store. That should work as long as I don't smash it with the input shaft on re-assembly, right? Probably just tap it into the torque converter pocket in the crank?
I do not want to spend another whole day wrestling with a transmission to access a twenty dollar part!
Anybody else had trouble with these? I heard some people knurl them to get a tight fit? I don't have a lathe. Red loctite on the o/d of the bushing before 'pressing' it in?
Kevin
Re: AAARgh! pilot bushing backed out of eagle crank! 408 sb [Re: radar] #203633
01/25/09 02:33 AM
01/25/09 02:33 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Red Loctite (272) is the wrong product, Loctite 680 Bearing Mount is designed for just what your dealing with..
Re: AAARgh! pilot bushing backed out of eagle crank! 408 sb [Re: radar] #203634
01/25/09 02:35 AM
01/25/09 02:35 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
the convertor register bushing is a B287.
I got one from PartsAmerica/Kragen for about $10
Re: AAARgh! pilot bushing backed out of eagle crank! 408 sb [Re: radar] #203635
01/25/09 02:40 AM
01/25/09 02:40 AM
Cab_Burge Online work
Cab_Burge  Online Work
did you indicate the bellhousing to the crankshaft register to see if the bellhaousing is centered on the crankshaft? if not that may be the reason the pilot bushing died, got ate up and wiggle out. If the input shaft of the transmission is not lined up on center to the center of the plilot bushing it will kill the pilot busk=hing in a hurry Been there, done that, Mopar small blocks are the worst offenders
