DRIVE SHAFT CLEARANCE #203428
01/24/09 10:00 PM
01/24/09 10:00 PM
Anonymous OP
Anonymous OP
I installed monoleafs and my car and had caltrac move the rearend centering pin 1inch back.The 28in tall tire was a inch away from the front wheel well and the right tire would hit the front wheelwell.So now the rear sits back more but now the driveshaft sticks out of the tranny alittle more.How far can the driveshaft stick out of the back of the tranny without breaking something?
Re: DRIVE SHAFT CLEARANCE #203429
01/24/09 10:04 PM
01/24/09 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
About 3/4" max
EDIT
as it would sit on the ground (curb height)
Re: DRIVE SHAFT CLEARANCE [Re: MR_P_BODY] #203430
01/24/09 10:10 PM
01/24/09 10:10 PM
Anonymous OP
Anonymous OP
THX MR P BODY.
Re: DRIVE SHAFT CLEARANCE #203431
01/25/09 11:01 AM
01/25/09 11:01 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Mr P Body is right and he know his stuff .With that said on my car I had a new shaft made measured everything 4 times (iam anal) talked to the company on the phone and said I did it right.My shaft pushed all the way in the tranny sticks out 3/4in and hooked up at rest is at 1-1/4in out.All is good but that is with a aftermarket yoke.Is it right I dont know.
